hi Guys
Im a bit of an amateur wen it comes to HIDs. I wanted to change mine as it has the boring yellow lights. I heard that it is expensive to fit the kit as the front bumper needs to come off. Is this true and is it feasable to go 4 a decent aftermarket kit($300) over here in Perth. Anyone had experiance wid this matter.?
Cheers
https://www.sau.com.au/forums/topic/293585-hid-lights/
NYTSKY has a thread in the group buy section, they are about $199 delivered, or there abouts.
The front bar does not need to come off, you should be able to do all of the installing yourself, its pretty straight forward.
Remove the old globes
Plug the new globe into the new ballast
Connect the +ve and -ve wires
Place new globe into headlight
Mount ballast securely
and that is about it
https://www.sau.com.au/forums/topic/293585-hid-lights/#findComment-4900855
My 2 cents worth....
1. The Chinese HID kits are around $120 delivered. Most likely, you'll need the D2R2 bulb (from memory) for the normal headlights, and a H4 Hi/Low beam for the other headlight housing (if you wanted the full conversion done). I personally would not go for any 'expensive' kit....For example, my friend bought a $300 kit 3 years ago (Made in some Euro country) for his BMW and recently had to replace his igniter...At the same time, I have HID'ed 3 cars so far with the Chinese kits and not one has failed me.
2. Go for the slim line HID igniters as there are the next gen HIDs and are based on IC rather than the conventional larger electronic components. Plus, since they are smaller, you can hide/find a better mounting spot.
3. I personally favour 8000k for the 'brightness' as it's white....(But Rianto would disagree with this...LOL)
4. Once you're done, make sure that you 'lower' your lenses as HID tend to blind oncoming traffic, so turn the direction down a bit.
5. Lastly, if yours is a coupe, to get the full white light look, you'll need to also convert the long side light (fogs). Much easier for the sedan as you only need T10 wedge bulbs.
https://www.sau.com.au/forums/topic/293585-hid-lights/#findComment-4902073
From My experence: I had done plenty of job to my coupe headlight:
1. Restore factory HID been remove by compliance. (D2R)
2. Upgrade the Lower High beam/Fog to H4 HID ( Which is totaly waste of money)
3. Upgrade the whole headlight to 06 projector one.
4. Upgrade the driving light of 06 headlight to HID (6000k)
5. Upgrade the low beam to 6000k to match color (D2S)
6. Change the city light of 06 light to white color to match HID
7. Change the bumper turning light to LED ( Not satisfied, try to find a better way)
8. Current working on a project of QUAD HID projector with QUAD Bi-Xeon.
From what I Know about the light:
1. To install the HID or do anything about headligth. If you want to do it fast, safe and not hurt yourself, remove the bumper, it only take you 20 min but save plenty of time to dig everthing from the exetrm narrow enging bay.
2. Upgrade the low section-Fog/high to HID is not a good idea.
No only a set of good chinese H4 Hi/Low Telescopic HID cost aroud AUD $150-$200.( the one can slide forward and backward to work both as High/Low)
Also the output is uneven, unsafe. blind everyone on road and make you looks stupid.
Also the reflect bowl is design for Halogen bulb, it work really bad with HID bulb by spay plenty light to the unnecessary area, that is reason why it looks bright outside but not bright for driver's eye.
3. For pre 2006 coupe the factory HID is not bad at all. If you after colors, just throw in a set of 6000k D2R bulb from ebay for $40, 1 set of Blue tint H4 for color match. Done. no need to upgrade as the output after upgrade is not surprise at all.
4. For the best output and look. Go for retro fit.
Cheers
Frank
https://www.sau.com.au/forums/topic/293585-hid-lights/#findComment-4902343
Nice post.
did you swap the projector (left <-> right)?
https://www.sau.com.au/forums/topic/293585-hid-lights/#findComment-4904893
Cheers
Frank
As has been said, great post.
Do I take from your point 3 & 4 that whilst the factory ones are good, your opinion would be that a retrofit of the ones such as is being run in the group-buy are a better option if you are coming from compliance-spec butchered parts?
https://www.sau.com.au/forums/topic/293585-hid-lights/#findComment-4906619
Sorry for the unclear points.
for point 3:
the Pre 2006 coupe head light came with factory reflect bowl HID for low beam, H4 reflect bowl for High/Fog. The performance is not bad at all. Only if some people like the HID a bit bluer, a set of 6000k D2R bolb will fit perfect. The blue tint H4 for High/Fog will make two part of light color match.
The Group buy is just a simple aftermarket PNP HID kit. They are no better than the OEM hid expect the bulb is newer. If you already have OEM HID, no need to change to that.
Regarding the Retrofit, I mean get the OEM projector into headlight housing like this
Buy doing this, you will have the best performance and OEM look.
Frank
https://www.sau.com.au/forums/topic/293585-hid-lights/#findComment-4907350
Sorry for hijacking this thread AND harrassing Frank, but its all good info...
So, I'm currently HID-less. :/
Would you consider it a good option Frank to buy the aftermarket HID's HERE
The Projector Kit from HERE ...RHD of course.
and shrouds to bling it up a little HERE
And will all that work together in blissful harmony?
https://www.sau.com.au/forums/topic/293585-hid-lights/#findComment-4908808
Hi mate:
what kind of headligth you get. I though all the 03+ coupe headlight came with HID and may or may not been removed by compliance.
Frank
https://www.sau.com.au/forums/topic/293585-hid-lights/#findComment-4909031
YEAH! Don't listen to Nelson... 4000K despite lower colour temp it actually outputs more Lumens (more lights).
I would personally stay up to 6000K as the max (5000K if you can find it is probably the best) as from 6000K onwards
it would start to look blue-ish then it will go purple and you actually start loosing illumination (becomes dimmer).
I hate blue-ish looking headlights, those colours are best for riced up shitboxes with more rust holes in the exhaust than 'go'.
always wondered what type of bulb they use for the long side... is it a customised illumination strip for V35?
https://www.sau.com.au/forums/topic/293585-hid-lights/#findComment-4912156
