hey all,
I am going to be pulling apart my r33..let me know if anyone needs any parts..will try get pics up asap
Engine is in good nic
aftermarket parts off the top of my head -
apexi 3" front pipe
highflow cat from justjap
nismo catback exhaust
split dump pipe
front mount intercooler
apexi front strut brass
040 fuel pump
aftermarket front fenders (fitted to car)
if anything else comes to mind will post up
everything located in s.e melb
post here or pm me
https://www.sau.com.au/forums/topic/293630-wrecking-r33/
  • Replies 131
shot gun apexi front strut pending pics
damn. the tables have turned mate. lets just hope this one doesn't get sold from under ya :ninja:. i'll take that brace if john-e boi doesn't
oh and have you got a type m frontbar, reo bar (uncut) or headlights for sale?
https://www.sau.com.au/forums/topic/293630-wrecking-r33/#findComment-4901645
the engine has done about 85-90k
with the exhaust, it looks fairly stock so dont think it come off a gtr, the muffler has nismo stamped on it
with the seats i would rather sell the whole seat not just a little part sorry bud
the reo bar is uncut
will try get pics up this week
https://www.sau.com.au/forums/topic/293630-wrecking-r33/#findComment-4902161
hey
could you pm me ur ph number? i am interested in the intercooler. please let me know the brand and core size. also does it come with the piping kit? any pics will be appreciated. thanks in advance!!
https://www.sau.com.au/forums/topic/293630-wrecking-r33/#findComment-4903052
budwizer - ye can u post up the pic of the part u want
myskyride - with the intercooler it has piping too...id take 250ono for the set or 180 for just the intercooler no pipes
stripping full car so everything is available
everyone who pm'd me i will try get back to you all by tonite
https://www.sau.com.au/forums/topic/293630-wrecking-r33/#findComment-4903137
hey mate below is the picture..
i really only need the top section down to just below the headlights and that central bar that holds the bonnet catch.
but would probably be easier for you to cut like this has been.
what sorta price?
thanks
andrew
https://www.sau.com.au/forums/topic/293630-wrecking-r33/#findComment-4903201
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
