hey all,
I am going to be pulling apart my r33..let me know if anyone needs any parts..will try get pics up asap
Engine is in good nic
aftermarket parts off the top of my head -
apexi 3" front pipe
highflow cat from justjap
nismo catback exhaust
split dump pipe
front mount intercooler
apexi front strut brass
040 fuel pump
aftermarket front fenders (fitted to car)
if anything else comes to mind will post up
everything located in s.e melb
post here or pm me
https://www.sau.com.au/forums/topic/293630-wrecking-r33/
  • Replies 131
shot gun apexi front strut pending pics
damn. the tables have turned mate. lets just hope this one doesn't get sold from under ya :ninja:. i'll take that brace if john-e boi doesn't
oh and have you got a type m frontbar, reo bar (uncut) or headlights for sale?
https://www.sau.com.au/forums/topic/293630-wrecking-r33/#findComment-4901645
the engine has done about 85-90k
with the exhaust, it looks fairly stock so dont think it come off a gtr, the muffler has nismo stamped on it
with the seats i would rather sell the whole seat not just a little part sorry bud
the reo bar is uncut
will try get pics up this week
https://www.sau.com.au/forums/topic/293630-wrecking-r33/#findComment-4902161
hey
could you pm me ur ph number? i am interested in the intercooler. please let me know the brand and core size. also does it come with the piping kit? any pics will be appreciated. thanks in advance!!
https://www.sau.com.au/forums/topic/293630-wrecking-r33/#findComment-4903052
budwizer - ye can u post up the pic of the part u want
myskyride - with the intercooler it has piping too...id take 250ono for the set or 180 for just the intercooler no pipes
stripping full car so everything is available
everyone who pm'd me i will try get back to you all by tonite
https://www.sau.com.au/forums/topic/293630-wrecking-r33/#findComment-4903137
hey mate below is the picture..
i really only need the top section down to just below the headlights and that central bar that holds the bonnet catch.
but would probably be easier for you to cut like this has been.
what sorta price?
thanks
andrew
https://www.sau.com.au/forums/topic/293630-wrecking-r33/#findComment-4903201
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
