Hey Guys,
Over the last few weeks I have been feeling my driver side window stick a bit and this afternoon it stuck on the way up and isn't going anywhere. From my quick search around the forum it sounds like this is a common problem.
Does anyone know someone in or near Newcastle that can fix it?
Or how hard is it to fix yourself?
Thanks,
Scott
https://www.sau.com.au/forums/topic/293632-m35-stagea-window-stuck-down/
Hey Guys,
Thanks,
Scott
Scott had the same problem on my RS4 and it turned out to be the switch in the door, bad contact but the switch was a nightmare to pull apart and re-assemble, all the little balls and copper rocker pads kept falling out. Eventually the window failed altogether and this turned out to be a blown connector in the 4 window switch in the drivers door but an electrician friend soldered it and no more problems, don,t know if this is any help but if you do tackle it yourself take plenty of patience pills
mate if you get stuck, try the guys at altapac in kotara.
cant fault them on anything yet, if they cant do it they will know someone who will
hope it helps
Cheers mate,
Thats a good call. I'm near kotara so ill check them out today.
Window switches are Hirohito"s revenge. Ask any Nissan driver. Touch wood, the Stag has never given trouble by all my R30 have shagged switches at some stage. Used to get from Nissan for $90 but now dont bother.
If the switch is stuffed an cant be fixed to get the window up a lead from a battery with probes and just go through the wires to the switch until the window closes at least you will have the security .
Looks like its the motor.
So now I have to source a new one.
Any ideas???
try Nissan first. make sure you get a part number for the correct motor (different door = different part number) and have it put through Parts Master to see if any models here use the same part.
if you do not like the price that Nissan quote, maybe try Jesse Streeter ("streeter" on here) as he offers a shipping service direct from Japan and is very good to deal with for anything that does not require a container for shipping.
Just make sure you have the part number for him.
Edited by iamhe77
Thanks Guys,
I ill let you know how I go.
Quite often the brushes stick...get motor out and tap it a few times to free up (concrete floor works a treat) plug it in and test it before re installing.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
