  • Replies 57
dont be too shy with the boost.
i ran 6psi through my rb25de for over 50k
i eventually swapped engine and box for the factory turbo variety not really knowing how much longer the old donk would hold up.
when the old motor came out and the head came off it was in excellent condition. i should have been more firm with it! :P
in the end i do think its just easier and cheaper to an engine swap
dont worry too much about the brakes, i stop fine now with some decent pads.
dont even waste ya time trying to turbo an rb20de - just go buy a rb20det it will be cheaper by far
cheers
Yeah for a few of you guys it may be cheaper for the engine swap....in my case it isn't :D But as you can see there has been a fair bit of success with a few people putting a turbo on the N/A without any trouble.
You'll find most of the people that say it can't be done have never looked into it or just plain don't know what they're talking about.
It's good to have people like Squizz & crooser as pioneers in this area :D
for the conversion i used a GTS Link
after swapping engines i have gone back to a factory 25det ecu (mostly coz it was a lot easier to do so to get the car running asap)
knowing what i know now, i should have just swapped injectors and used a factory 25det ecu for the conversion. (the afm and wiring loom are all the same
in the r33) that would have solved all the tuning issues/time. and if it pinged u can just retard the base timing from the cas.
the perfect mod for a 33 gts4
the perfect mod for a 33 gts4 you reckon? What prices are we talking here crooser..?
Cheers
C
  • 4 weeks later...
Hold the excitement! The stocko injectors are way substandard…and apparently haven’t got a hope in hell of even running at low boost! Luckily the injectors I’ve been waiting on turned up today…so at least I’ll be able to get them in tonight. The biggest problem is getting another dyno spot to turn up sometime soon….unlikely.
It is indicating however that some decent power is going to be found as I’m sure the stocko ones are the R32 turbo top-feed item :(
Will update you guys in a couple of hours after I see my car.
Dan
PS: Turbo mirage ewwwwwww
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
