  • Replies 57
Still having troubles? Ok.. just looking at this, few things occur to me.. but i could be completely wrong.
It sounds like you're not actually getting enough pressure to the injectors in the first place, and that sems to be the source. Even stock N/a injectors should be enough to run a little boost. Have you checked the fuel pressure at the rail, and is within range ? May be useful to rig up a pressure tester to the rail and see what you're getting. If you're not getting the required pressure in, the injectors won't be working correctly and hence may reach max cycle prematurely. Also, check your fuel pressure reg? is there any difference between the stock fuel pressure reg, and say the turbo thing. Again, the lack of pressure to the rail thing springs to mind.
Also the other is to check the source of course, and that is the fuel pump itself. Are there differences between the n/a fuel pump and turbo fuel pump in terms of flow? I know on like the GTS R33 there can be a difference.
Lastly, the AFM signal and when its maxing out is a bit of a telling sign. You tried other AFMs? it seems similar to the circumstances reached when you max out a stock GTS-T AFM when you hit the 220rwkw mark (and hence go for a Z32) when it can *appear* the injectors are maxing out .. and with the emanage, i believe you need a separate injector harness to be able to control/dictate the injector pulse rate which will be important in this situation to override the ECU's injector timings.
.. so overall it sounds more like other factors than the injectors at work here.. and it may just be the end result of them maxing out that is the most obvious.
Hope that might be some food for thought, if you haven't already gone through it all (probably have :()
p.s. thanks for the toulene!
The new injectors are in and It's now running VERY rich...so looks like it was just the stock ones not having the balls. My AFM is the turbo one anyway so not a problem...I've also got the injector harness hooked up.
The fuel pump is capable of flowing the pressure, also the fuel rail is up to the job.
The second the 385cc injectors were in, everything seemed to be OK...Thursday will be the final check on the dyno and with A/F ratios.
Dan
A few pics I quickly took, excuse the inch of dirt in the engine bay :D
I can honestly say even driving the car around at less than 3000rpm (to prevent any misadventure until full tune) it would still out perform the standard car revving the balls off it!
  • 4 weeks later...
Hello Dan. Very intersested in what you have done as I would like to do exactly the same thing with my R34. Bought it in December and thought I could just whack a turbo on it but told it would be better to do an engine swap. Have you posted outcome of the operation and procedure.
Any info would be greatly appreciated.
  • 3 weeks later...
  • 3 months later...
Heya, got on the dyno, but was getting some bad timing retarding happening...waiting for my ignition harness to arrive for the e-manage.....then I can sort out the timing spikes back to something a bit less advanced. Will try and do it in time for the Mercury Motorsport Dyno weekend.'
I'm suprised your insurance was against the idea...my insurance didn't increase at all.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
