Hi all,
Just picked up my series 3 R33 GTR and on the way home noticed that the tacho will 'stick' at revs, then jump around the dial and generally not do what it should :banana:
Is this a common issue? Any easy repairs/diagnosis on the issue?
Cheers
Daniel
(also, I've seen some series 3 with the standard 180km/h speedo, and others with a nismo 320km/h speedo - both have claimed it's factory OEM fitment for the series 3 - which really is??)
https://www.sau.com.au/forums/topic/293669-r33-gtr-series-3-dash-issue/
Excuse my noob-ness. I've done a search and found that this is a pretty common issue. Also found the DIY cluster removal so I'll give it a go on the weekend and check the connectors on the back of the cluster. If that doesn't fix it, then I suppose I'm up for a new cluster :banana:
The 180 km speedo is standard equipment in Japan for new cars.
The Nismo speedo and / or complete cluster is an after market replacement that is simply a plug and play upgrade. The components in a GTR cluster and Nismo cluster are interchangeable and in my case I transferred my GTR tacho to the Nismo cluster as I preferred it to the Nismo tacho. If you go for a Nismo cluster shop around before you buy as you can same hundreds of dollars on the same item.
Thanks mate - I was pretty certain that the 180km/h speedo was the original factory fitment (like all other imports i've dealt with).
Hopefully I won't need to replace my cluster, but I'll definitely shop around if it comes to that. Cheers :(
