Hey Guys,
Hope someone can help even though its not a skyline.
I have a N15 Pulsar S2 SSS. I installed my cd and unfortunately i cant work out why or whats shorting out my lights. I have checked and replaced fuses but everytime i turn the headlights on the fuse blows.
Headlights still work. cd working. cabin lights still work BUT no tail lights or Dash...is there a wire in that dash thats tail or dash light related??
Please help..........
Cheers
Its a ground issue. Either you have put a screw in a place it shouldn't go into your deck and therefore making a cercuit fault, or you just haven't ground the deck to the right place. Check those things mate.
Thanks mate. I ll check my wiring tonight. I will earth my wires through the chasis (ie cd player) and earth the negative on the battery to chassis aswell.
Cheers to all for reading!
Illumination wire, when the parkers are turned on this wire is given voltage, it's what tells the headunit/dash lights to dim when the parkers/headlights are turned on.
No sure what colour wire this is in the 34, theres a few schematics floating around the forums though.
i have a feeling this is whats causing it to short out. there was a heap of wires which i didnt use BUT ASSUMED that they (ie speaker wires) were not active. BIG NO NO on my behalf cause i should have sealed all wires with electrical tape. i ll check again tonight and hope im on the right track.
the only thing that worries me at the moment is that when i push the brakes, brake lights work and not the other lamps in the tail lights. its confusing cause only the dash and non brake tail lights dont work...keep you guys posted.
Anyone with other ideas, more than welcome to add.
N14's have an interesting design that people run into all the time - people assume that the black wire in the dash stereo wiring is a ground, when it's actually the illumination wire. They wire up the stereo ground to the illumination, and depending on loads can end up blowing the fuse... Kinda wonder if the N15 might be different or not...
Most CD/Head Unit have 3 wires for power supply,
1 Yellow Battery Positive
2 Red Ignition/Acc
3 Black Earth
More than likely the black wire from the head unit has been connected to the dash illumation wire.Cut this wire replace fuse, lights should work and head unit will as it still gets an earth via the aerial.Connect the black wire directly to earth.
2 Red Ignition/Acc
3 Black Earth
wish it was that easy. the first path i took was disconnecting the cd player entirely but it still blow fuses.
i have tried following lines back to the stork and other wires around where i have installed the cd player to see if there were any crushed lines - no such luck.
Im thinking that i may have shorted a line somewhere while
1) cabling wires etc for amp speakers.
2) crushing a while which is stork related in the dash.
Anyway - so many headaches. final option is auto electrician.
2 Red Ignition/Acc
3 Black Earth
:banana: YOU CHAMPION!! Thanks mate.
I revoke what i said in the above. I just went out there, completly removed all wires including H/U and wiring loom put another fuse in there and IT WORKED !
i see where i went wrong. Illumination wire was what killed it.
NO MORE ASSUMPTIONS. I should have checked the wiring diagram to begin with.
Cheers to all who have added comments.
Lesson Learnt!
Lesson Learnt!
No worries glad to help as i`m an Auto Electrician..lol
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
