hey all, I thought iI would pop this up here for all you to ponder. its got me stumped.
I have a 32 gtst, which occasionally the left side headlight wont work. OK sounds like a loose wire or bad earth.
Except when you turn the headlights on and off again it works the second time.
only thing i can think of is maby dirty contacts in the switch?
it has also done it when you turn the high beam off, not very often but it has done it.
any ideas of what to look at and what to try?
cheers jamie :banana:
https://www.sau.com.au/forums/topic/293689-strange-headlight-problems-32-gtst/
I had the same problem, exept my right headlight didnt work at all. What i did was meter the voltage without the globe connected. both headlights metered the same but when a globe was plugged in it wouldnt work. The way i fixed it was re-wired both headlights with relays on it. Its about a hour worth of work and will cost about $20 for the relays but it fixed it and havent had a problem since. I have read of people pulling the switch apart and cleaning and bending the connections on the switch,i just cbf pulling the switch apart.
my 2c anyways.
cheers jamie :D
Nissans use a 4 circuit headlamp switch (high low right left)therefore 4 contacts are used.More than likely you will have a dirty connection on one ,easy fix fine wet and dry paper and retension contact
Yep, odds on it's actual headlight switch in the dash. Nissan decided to have the lights draw all the current through this switch, instead of run a relay. So over time the plastic contact lugs melt.
When my car did this, I just got a 2nd hand switch which fixed it. Plan to wire up the relays when i've got some spare time.
If you wanna have a go, this should help: http://www.danielsternlighting.com/tech/relays/relays.html
Nissan uses multiple ground paths for lights , look near the radiator /headlight you should see a ring terminal on a bolt. on each side, can be rusted or loose from years of abuse.
also the switches fail often, similar issues on my R31 , pulled the switch apart (frosted plastic bit on the back of the switch )and the contacts needed small tweak/filing to contact again(poor man fix)
or switch out the headlight switch fixes it 90% of the time if the grounds , relays are good
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
