Great stuff guys... awesome info as always Timmeh you are _the_ authority on stagea spec's lol.
RB_Ryan yes I was getting viscous confused with mechanical. Been reading the group buy threads for kaaz centres too much lol.
Anybody have an idea how much it would cost in labour for a shop to open the diff' to change centres (Simon)? Might as well replace rear subframe bushes while there? Replacement mounting bushes for the diff itself available? (mine look a bit worse-for-wear).
Simon interesting to read that you went for an LSD upgrade - and what kind of a difference did it make? Do you feel like you've got more traction, or less? Just wonder what attesa would make of an LSD... would it start to oversteer 'cause it can, or would it start to understeer because it's not got more traction at the rear...
cost me around $250 from specialist diff shop.
I do feel like I have more traction, maybe psychological, have since upped boost and fitted highflow and the rears dont even think about letting go. I occasionally feel the fronts slipping (wet) but understandable when the weight goes to rears in accel.
Im not one to throw it around corners anymore, but i would doubt whether it makes any difference to steering, mine feels very neutral, maybe it might in a 2wd model.
There is 2 types of 6 bolt axles
Auto's are 3x2
RS4s and 260rs and GTR are 6x1. Larger diameter and stronger.
I currently have a RS4S complete rear end sitting here if you need something checked
I just looked under the back of my car. It is/was a factory auto series 2 but it has the 6x1 bolt pattern on the diff output shafts and has the same diameter shafts as the the new manual cradle and diff I have sitting waiting to go in. Did a quick measure of the rear RH driveshaft lengths and the auto was 25mm longer which makes sense due to the wider track.
So does that mean my car may have come from factory with a LSD the same as a RS4 or 260rs?
Will FAST tell me?
Darrin, fast can tell you if you have a factory fitted LSD, you can only just make it out from the japanese/english character mess fast give's you. do you have fast? if so enter your vin, and in the row of buttons across the top you will see one of them has a blue "OP" on it. press that one and it will list any options fitted. there may be some that are just japanese characters or a mix of english and japanese but you should be able to make it out if it has a LSD. if you dont have fast pm me your vin and i'll have a look for you :P
Edited by QWK32
  • 7 years later...
Auto's are 3x2
Are these two axles the same except for the bolt pattern? As I am wanting to put a 260rs rear diff in but I am running an auto diff with the 3×2 pattern.
Best if you can get a complete rear end. I don't know if you can just use the diff centre. If you are planning to change to 6x1 axles carefully check the lengths as there is a number of sizes in 6x1 and they are different left and right.
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
