hey guys
iv got a hks 2540 for sale. was going to put it on my car but think i need a new bottom end.
its genuine and is in very good nick.
no actuator or lines included. i can get some if you want
$1200 plus postage ono.
i live in japan so will be sent from there, or if not bought quickly ill send it to my brother and can then be picked up from toowoomba or posted within aust.
postage will be between 100 and about 180 depending on sea or air
contact: [email protected]
tubo core info:
GARRETT
YG 6069J
GT2540-46T
446179-17
https://www.sau.com.au/forums/topic/293700-hks-2540/
You live in Japan! Your way cooler than us ! lol GL with sale good turbo and cheap as f**k
if i advertised it for more money and it took 1 month to get to someone theyd wonder why...if they no where its coming from straight up theres no confusion. :)
can be sent from japan or for more money from within australia or picked up in australia also
https://www.sau.com.au/forums/topic/293700-hks-2540/#findComment-4903133
rb25 :down:
are u sure , coz it looks like it has studs and its a t25 flage commonly found on a set of RB26 , they require two of them , way not for the rb 25 !dump different as well , may fit sr 20 with a lot of muckin around , do u have the pair of these for the rb 26
https://www.sau.com.au/forums/topic/293700-hks-2540/#findComment-4903307
when i bought it i bought it as an rb turbo. ill go get it out and check.
i dont have another if it turns out to be a gtr turbo but i can get one very easy for a bit more.
https://www.sau.com.au/forums/topic/293700-hks-2540/#findComment-4903482
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
