Hey guys, I gave this a quick search, though I wasn't sure as to what forums I'd find an answer in, nor was I sure what to search for exactly lol.
This is (as of about 6 months ago) my car:
http://www.skylinesaustralia.com/forums/R3...ht-t242518.html
That FS thread gives a decent list of all current mods/parts on the car, and the only things I've done to it since I got it is steering component replacements (tie rod ends etc) and all exhaust gaskets from the manifold back. No performance upgrades.
Now that I've had those 2 repairs done it it, I'm looking to build it up a little. Currently making 167.7rwkw @ 11psi on a mainline dyno.
Unfortunately due to my inexperience with modifying cars, I'm unsure what do start with. I have a good idea on what to do overall, but not what to do first. This is where I'm hoping some of you guys can help out a little :(
As the car is technically a daily until probably around March next year (when I move out after overseas trip), I don't want to go TOO far and have something that's not worth putting the kms onto. I'd like to aim for anywhere between 220rwkw - 250rwkw until this time.
Any suggestions as to where NOT to start would also be much appreciate if you can't put in any input as to what to do first :(
Thanks guys :D
https://www.sau.com.au/forums/topic/293715-looking-to-begin-further-mods/
Oh? Interesting. I'd thought maybe a little more than that would be needed, but that's probably good! What kind of $$$ am I looking at for something like a Vipec? And any particular brand for injectors?
sard or nismo injectors and a Vipec or second hand PFC and a tune and you'll get 230-250rwkw no probs. So around $2.5-3K and your there. Not sure about the exhaust either?
But easy mods really.
  • 1 month later...
ok so bumping my thread...I haven't had the time to organise any mods as yet, but after having it run on the dyno to investigate a few odd engine sounds that only appear under load (gas leak sound ~2400rpm, whistle sound ~3500 - 5000rpm) and being told that the mechanic couldn't replicate any of the sounds, but not to worry about them as they won't be something vital (ie. cat could be bung, BOV could be leaking under full boost)...
The upside of this dyno run is that the CAS was out, causing retarded timing. Not sure how many degrees it was out by, but after lining it up correctly, the car made 190.8rwkw @ 184kp/h - like I said, same mods as above...
Any rough ideas on what power figure I could achieve with Injectors, pump, and Nistune? Still aiming for 230-250rwkw, but after having seen power increases from some other people's runs, I got no idea what to expect haha
Thanks again oh-knowledgable ones :)
  • 3 weeks later...
Hey troy, as it was my car, and I had the same thoughts as you, I was told to go with a decent set of injectors and ecu.. Rb25 AFM's work well for the power you are wanting to acheive, so I would suggest a Power FC, they are readily available second hand, and they are a cake-walk to install and tune.
Therefore my suggestion would be in this order.
Power fc
Injectors
Full service
Tune
See where youre at when this all goes down and you should be good for what your chasing.
Then stage two would be imo.
Turbo upgrade
Cooling system revised, including radiator, and oil cooler
Air intake system revised, AFM and CAI
Re-tune
This would see the car becoming quite a scary and fun little street car for what it is..
Really it all comes down to the specs of that highflow turbo and what power it will make. Any information on what company highflowed it? Will give you a better indication of what power it will most likely make and how far you can push it.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
