Rb26 Drysump/external Oil Pump
T04GTR
 Share
  • 4 months later...
  • Replies 53
I'm currently setting up a drysump for my rb30/26 vl commodore.
I got a peterson r4 pump for quite cheap, i just dont know where i can mount it.
I've attached some pictures of it in a hope that you guys can point me in the right direction.
I want to have 3 -12 scavenge stages in the sump and one -10 scavenge from the head.
-16 to and from the tank, and -12 to the block. BUT I THINK the scavenge inlets are on the wrong side,
cos when spun clockwise the pump looks like it pumps the wrong way.
  • 3 months later...
Why are you wanting 6 stages Mike? 4 is enough for 1 x head and 2 in the sump, plus the pressure stage.
As a general rule you dont want to scavenge the super hot foamy oil from the turbo's either as its not good for the scavenge stage. Instead letting that oil return to the sump via conventional means so it can cool down and release air bubbles.
I'd like to have a try mounting one where the power steering pump is, drive it off the exhaust cam gear, and go with an electric power steering pump.
Edited by GTRNUR
There are some second hands pumps available at good prices that are 6-stage. I was thinking 3 on the RHS of sump, one at the rear and one off the head and obviosuly pressure.
I have read exactly what you have just mentioned about sucking in foamly oil, etc as there is not enough to scavange having so many stages. In between my previous post and what I have read since I do not think it is a good idea.
I do not actually think a 6-stage will fit, I think it will hit the engine mount which ever side you put it on. What you suggested is a good idea too, only thing is you are scavanging from higher up.
Cheers for that Ian, how many stages do you have on your VW?
The pump on the bug is 3 x 1.75" scavenge stages and 1 x 1.25 pressure stage. I use a -16 from the sump and 2 x -12's from each rocker cover.
Having re thought it... even mounting an oil pump where the power steering pump is located would be tricky. Available room is at a premium and clearing the turbo intakes, plumbing etc would be a challenge.
I am in the process of fitting a Peterson 5 stage dry sump kit from "dazmo"
There is still a bit of room behind there. The 6 stage will fit but you will have to block the front turbo oil return hose and tee it to the rear if required.
A small plug for dazmo; his dry sump kit is fairly well designed, packaged and priced. I am impressed with the quality.
this is my 5 stage one. as you can see there is not enough room for it to come back any more because of the engine mount.
this is with a highmout single turbo, stock twins,no chance of fitting.
depending on how the last section is, you may be able to fit it, but i doubt it.
Thanks T04GTR I was waiting for you to post! Do you have any details on your sump mods? I understand if you want to keep it close to your chest, feel free to PM me. Cheers.
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
