  • 4 months later...
  • Replies 53
I'm currently setting up a drysump for my rb30/26 vl commodore.
I got a peterson r4 pump for quite cheap, i just dont know where i can mount it.
I've attached some pictures of it in a hope that you guys can point me in the right direction.
I want to have 3 -12 scavenge stages in the sump and one -10 scavenge from the head.
-16 to and from the tank, and -12 to the block. BUT I THINK the scavenge inlets are on the wrong side,
cos when spun clockwise the pump looks like it pumps the wrong way.
  • 3 months later...
Bringing the thread back to life, does anyone know if you can fit a 6 stage dry sump pump to an RB26? Has it been done before? Pump will be mounted on a bracket where the air-con. was originally fitted.
Why are you wanting 6 stages Mike? 4 is enough for 1 x head and 2 in the sump, plus the pressure stage.
As a general rule you dont want to scavenge the super hot foamy oil from the turbo's either as its not good for the scavenge stage. Instead letting that oil return to the sump via conventional means so it can cool down and release air bubbles.
I'd like to have a try mounting one where the power steering pump is, drive it off the exhaust cam gear, and go with an electric power steering pump.
Edited by GTRNUR
There are some second hands pumps available at good prices that are 6-stage. I was thinking 3 on the RHS of sump, one at the rear and one off the head and obviosuly pressure.
I have read exactly what you have just mentioned about sucking in foamly oil, etc as there is not enough to scavange having so many stages. In between my previous post and what I have read since I do not think it is a good idea.
I do not actually think a 6-stage will fit, I think it will hit the engine mount which ever side you put it on. What you suggested is a good idea too, only thing is you are scavanging from higher up.
Cheers for that Ian, how many stages do you have on your VW?
The pump on the bug is 3 x 1.75" scavenge stages and 1 x 1.25 pressure stage. I use a -16 from the sump and 2 x -12's from each rocker cover.
Having re thought it... even mounting an oil pump where the power steering pump is located would be tricky. Available room is at a premium and clearing the turbo intakes, plumbing etc would be a challenge.
I am in the process of fitting a Peterson 5 stage dry sump kit from "dazmo"
There is still a bit of room behind there. The 6 stage will fit but you will have to block the front turbo oil return hose and tee it to the rear if required.
A small plug for dazmo; his dry sump kit is fairly well designed, packaged and priced. I am impressed with the quality.
this is my 5 stage one. as you can see there is not enough room for it to come back any more because of the engine mount.
this is with a highmout single turbo, stock twins,no chance of fitting.
depending on how the last section is, you may be able to fit it, but i doubt it.
Thanks T04GTR I was waiting for you to post! Do you have any details on your sump mods? I understand if you want to keep it close to your chest, feel free to PM me. Cheers.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
