Hey Guys,
I finally got a set of wheels for the M35... I got some Enkei GTC01 in 19x8.5 +22 Tyres are 225/40/19
The fitment is perfect! exactly what I was going for in terms of filling the guards. Check out the pics
Some of you may remember I tried running a staggered set a few months back but had attesa issues.... Well I have now bought a set of 4 matching wheels and tyres, and still have the attessa shifting torque to the front when it doesnt need to.
Has anyone had this issue with aftermarket wheels on the M35? I never had this problem on my C34 stagea. Any advice/ideas would be great.
In the mean time check all the pics below! Im loving them :) I now have loads of room for 350Z Brembos :bunny:
Ben.
https://www.sau.com.au/forums/topic/293758-got-wheels-on-my-m35-lots-of-pics/
I am so jealous. (the only way they could be any better was if they in dark gun metal and then they would be perfect for my silver ARX, LOL)
I have no idea about the ATESA issue. Are you getting any fault codes? Have you checked the fluid in the ATESA bottle?
Other wise not sure what it is.
Cheers
Andy
hmmm, that would look great on your car Andy (when?), although I don't think Ben could have picked a nicer wheel colour to compliment the dark blue.
(could use a bit of dish though :) )
Hate to ask Ben, but when does it put torque to the front wheels?
Edited by iamhe77
Any time its under heavy load. if you gently accelerate its no problem, but if you give it a little it puts torque through. And yes im quite sure its no where near breaking traction. If the standard wheels are on, it stops doing it...
looks great ben.......no idea on the problem you are talking about but I do remember our GTR doing the same thing years ago when we changed wheels.... unless you have errors coming up on your screen I would not worry about it.
should get your nuts painted same as ur car :down:
bit rude CL11QE!....not to mention the sanding back!!!....but whatever you into!!!
Edited by Jetwreck
I drove a M35 that had the torque split gauges and the owner said if you give it a bit harder accelleration the power will move to front wheels and u can see it on the guage... maybe your problem is not really a problem. Any others notice this or does the torque split only happen when u break traction?
on hard acceleration
the gauge moves usually on atessa systems
Well when I put the standard wheels on, the only time the atessa comes on is when its breaking traction. There is a noticable difference on the guage between the two wheel sets.
Mind you... if there wasnt a guage I wouldnt think there is a problem. everything runs perfectly, no warning lights, or vibrations or anything!
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
