  • Forsale: items and prices
    • Silvertop Rb20 turbo + stock manifold and 2.5inch\3inch dump pipe to suit r31 $450
    • R32 brakes. sumitomo Calipers rebuilt and painted gold with brand new performance pads. New slotted rotas 290mm/30mm. And all bolts. $650
    • HR31 struts/springs/hubs/Disk/Calipers and bolts and control arms $500
    • Silvertop rb20 crossover pipe with BOV relocator cover. $50ono
    • Silvertop rb20 rubber front turbo compressor induction hose. $30ono
    • R31 radiator dual 32mm core with one 12inch thermo fan used would be fine to put on your daily (radiator inlet snout is half broken and thermo fan has a crack on the side of it but i was using both fine $50ono :down:
Condition:
  • Turbo good condition minimal shaft play turbo has done around 80,000kms and no more than 13psi comes with oil and water lines dump pipe and mani2turbo gasket. ready to go.
  • Brakes in excellent condition have not been on the car since built.
[*]One of the bottom of the struts is a bit damaged other than that everything looks to be in good condition
Reason for selling: Upgraded turbo and changed plans going S13 coilover insted.
Nearest Offers considered on all items.
Located in NSW Concord/north strathfield area. Prefer pickup.
all pms replied to. R32 rotas where blanks and where drilled too 4x114.4 to be used with the import struts.
Prices neg. good brake upgrade for the 31's
All above items are neg. Will do brake 32 brakes Brakes and import struts for $900
New parts added from R32 rb20det
Coilpacks have done approx. 80 000kms full set of 6 $250ono
Green AFM approx. 80 000kms (mesh AFTER sensor has been removed for better flow $150ono
Standard Rb20 Injectors Full set approx 80 000kms Make an offer.
Turbo smart Vee-Port BOV (atmo only) sounds good does its job not even 6months old retail around $300 asking around $170
cheers
  • 3 weeks later...
    • R31 radiator dual 32mm core with one 12inch thermo fan used would be fine to put on your daily (radiator inlet snout is half broken and thermo fan has a crack on the side of it but i was using both fine $15 :)
Condition:
R32 rb20det ECU. Good condition make an offer
cheers
Some new parts
  • 4 weeks later...
hey bud got a rear pair with new pads $50
Would you be willing to separate R31 calipers?? I just need the rear pair.
Pm me & let me know please....
  • 4 weeks later...
To4e external gated turbo went good on car looks in top condition
More rb20 parts just ask
cheers
Pm offers n questions
  • 1 year later...
  • 6 years later...
