Hey all,
Can't seem to get rid of my ceffy as a whole for a redic cheap price..see here: http://nissansilvia.com/forums/index.php?showtopic=412623
So I'm going to part it out and let other people enjoy the fruits of my labour! Most parts are in used condition and I'll get some more detailed photos soon.
READ THIS: Will not post because I don't have time!
Here goes...
HKS Turbo kit for RB20/25 - Originally off an RB25 this thing will be seriously responsive and make an easy 250kw (comes on hard on the RB20!)
Whole kit = $2300
Turbo / Gate / Manifold = $2200
Seperately =
HKS GT2835 Ball bearing turbo - Rebuilt 4000k's ago because it went bang with the old motor. Brand new HKS core (paid $1500!) is seriously new and has been slightly highflowed = $1400
HKS Tuned length Stainless highmount manifold = $600
HKS 50mm Race gate = $400
3in Dump w/heat wrap = $200
Braided lines for turbo = $100
Total = $2700 so save yourself $400 by buying the kit!
Pics:
Cefiro specific parts:
3in Sebring cat back - Quiet on idle, screams on boost! It's a straight pipe into a rear muffler = $200
Pics:
M-Sports genuine front guards = $300
Pics:
Cusco front strut brace for Cefiro / Laurel - It's the good one that goes back and runs along the firewall = $120
Pics:
Parts for EVERYONE!!
Trust 10 Row oil cooler (Painted black for stealth) - With braided lines and sandwich plate / thermostat = $500
No pics, but it looks like a Trust oil cooler lol (No relocater!)
Defi Din gauges - Almost brand new, used for about 3 months (Oil Temp, Pressure, Water Temp) = $600
Pics:
Work Emotion Kai 17 x 9 +17 all round - Slight gutter rash on a couple of the rims but hardly noticable on the car - Falken 452's on the front and BRAND NEW cheapies on the rear = $2000
Pics:
Bride Zeta II on genuine SUPER LOW Bride rail (3 months old from Japan!) = $750
Pics:
Greddy Catch can - Brand new with silicon on hose for sealing power = $80 (Located in East St kilda)
Pics:
Nissan GKTech steering shaft spacer Brand new and still in wrapper = $15 (Located in East St kilda)
No pics...Google it!
Think that's about it for now.
Parts are located in Diamond Creek (NE Melb suburbs) and are all still on the car so I will have to pull them off if people are keen :down:
Contact me on 0412 033 449.
Thanks.
Edited by konect
https://www.sau.com.au/forums/topic/293793-stripping-most-of-my-cefiro/
Exhaust - SOLD
Steering Shaft spacer - SOLD
Strut Brace - SOLD PENDING PAYMENT
God damn I wish SAU would fix the Edit function on the original post!!
This is the edit: Have someone that can post the parts now so can send interstate!!
Edited by konect
Hi do you know if those Greddy catch cans are baffled inside or not.
cheers,
Dave.
I don't believe they are, however the holes are big enough to stick some steel wool in there.
FYI - Can is on hold until next Wednesday (4 Nov) for someone.
  • 1 month later...
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
