Hey guys, recently purchased myself a series 2 Stagea RB25DET Neo and the other day taking it on a long drive and after arriving home i could hear a almost knocking noise from the engine (barley noticeable but bad enough to make me concerned) so i popped the hood and had a listen.- the noise is worse when hot, cant be heard off of idle, isn't hearable at idle when cold and using the screw driver trick the noise can be hear from the front (near runners 1,2) of the intake manifold but the noise can also be heard from the RH rear rocker cover... Just wondering if anyone has had any similar experiences.
Thinking it could be one of the rear cam/shim clearance.-noise at the back of the rocker cover makes me think that.
Any advice/experiences would be greatly appreciated.
Some photos of the Joy.
Thanks.
Firstly, congratulations on your purchase and welcome to SAU.
Is it only audible with the engine off and after a long drive, when the engine has had a chance to reach full operating temps? If it's a ticking noise with the engine off, it's most likely only the regular sound of the engine cooling down.
Because there are different metals used for different parts of the engine, they all cool at different rates, and the stretching and contracting of those metals at different rates is what causes that noise.
Thanks mate.
Nah i know that noise, the noise Im hearing is always at idle when hot and its more of a knock then a tick (sorry about the title description).
Yeah looking forward too a couple of Stagea cruises.
and too take some more photos.
noise from the intake would more than likley be injector tap or worse an air leak (you would notice sh***y running though), my s1 injectors are quite loud but they have been reco'd, use you screwdriver trick on the injectors and you will see what im talking about, to listen for an air leak, i use a piece of vacum hose stuck in my ear one end and point it around the intake gasket you will be suprised at what you can hear doing this, the noise at the back of the tapper cover could be a sticky lifter maybe, run some nulon lifter free through it next oil change and see how it goes!!
Edited by fat-lad
lol, can we get a vid of you doing this? :banana:
Cheers for the input fellas. Okay so today i grabbed some of that Wynns engine flush and put it in the car and then drove the car to trade school ( wynns man said it was okay to leave it in over night). Got too trade school noise was still there a couple of the blokes had a listen and said bottom end. But bottom end is more under load and higher up in revs. So after trade school i drove it too work (I'm an apprentice mechanic)-And let the other mechanics have a listen all of them couldn't distinguish where or what it was possibly shims/lifters. (unsure if series 2 are hydraulic or not).
But the noise is that quite when they were trying to listen too it they said don't worry about it and wait a little bit and see if it gets worse.
So i drained the engine oil etc. ran it again, drained it again. Put some 10w40 in and started her up, drove the car home and the noise was still there.
So im at the point where i am waiting and hoping that it doesn't get worse. (and ill be keeping a close ear out for any change what so ever)
Thanks again.
My previous s2 used to make a faint knocking noise when idling. Wasn't loud or anything and didn't sound that bad. It never got any worse so I never did anything about it. Pretty sure I was told it was likely the lifters...so my guess is that its fairly normal on the NEO engines.
I owned the car for 2 years and never had any issues from the engine. The RB25's are pretty solid. Not the smoothest idle i've heard but it was always a strong performer. :D
RB engines can smooth idle.Ghostrider sent me a pic of his 1UZ Cressida that had a 50c piece standing up with motor running. LOL. I sent a pic back of my S1 with the 50c standing, so they can idle smooth. I must admit though that had just give it a major service and changed all the belts.
On the S2, at the back of the tappet cover is a polution control solenoid. It tickers away at idle and goes away as soon as you put some revs in.
Mazda V6's used to have the same problem and the factory solution was to rubber mount the solenoid.
Either way, the NEO is a solid motor, thrash it till blows!
Yeah come to the dyno day.... So you can meet some of the SA stag crew and chuck it on the rollers to see if its running as it should and then you will have a base figure before mods :happy:
Looking forward to catching up with you all.
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
