Ive recently moved from VIC to the gold coast and am wondering whats involved in getting my car registered in QLD.
My VIC rego runs out tomorrow :cheers:
Wondering how picky they are on a safety certificate, what i need to make sure is in good nick etc etc. Not sure if its much different from VIC and their RWC's.
And also anyone know someone i can go and see to get a "friendly" safety certificate as im keeping the car.
Thanks for any help/advice :(
https://www.sau.com.au/forums/topic/29384-safety-certificates/
RWC costs about $50 to get done. I'm not exacly sure on the process but im sure all you have to do is get a RWC then goto queensland transport pay for rego and they should issue you with QLD plates and you surrender your VIC ones. Give them a call before you go there and ask if there is anything else required. I'm sure its pretty straight forward.
MJ's pretty much right.
I swapped from VIC to QLD 6 months ago or so (not the skyline).
Get a RWC/SC, cost about $50.20.
Go to QT, hand in your plates, show em your SC, and they give you your new plates.
You can get a rebate on your VIC reg but I'd recommend against it apparently they apply 'fees' to that process.
I just waited till my VIC rego nearly ran out which was 11 months, your supposed to swap over the reg within 3 months but who's checking?
Unfortunately my rego has run out today.. :rofl:
I assume i can pay for a permit to drive it around to get it roadworthy yeh?
And also when going for the roadworthy, that 50 odd bucks, does that cover me to come back if i dont pass the first time around or do i have to cough up cash each time i go?
Thanks guys
When you do this, do they check over the car for um, "stuff" or is it just a swap plate job, e.g. would you have to remove some things. Its a while b4 i have to worry about that though.
Otherwise the SC thing sounds pretty much the same as VIC.
Not for me.
Just handed in the plates, gave em the SC, they give you new plates and your away.
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
