Hey how u going guys I'm new to this site. I just bought an R32 Skyline from Melbourne n drove it to Adelaide. It's still registered for 6 months with Victorian rego. I went to rgister it and transfer it into my name but I couldn't get it registered cuz they couldn't find a compliance plate so I got told they'll mail something out and then I need to go to Regency for a full Inspection. Any advice ?
https://www.sau.com.au/forums/topic/293844-hello/
If you have any rims, coilovers, overly load exhausts/decats, shit non-ADR compliant steering wheel, gauges everywhere boost controllers, turbo timers - Will all need to be changed to avoid a full regency inspection.
https://www.sau.com.au/forums/topic/293844-hello/#findComment-4904115
Welcome mate.
If it was complied in VIC prior to your purchase, it should only require a VIN & ENG No check.....can be done at Lonsdale.
are they strict at lonsdale? i know they are pretty strict at regency... just wanted to know lol
https://www.sau.com.au/forums/topic/293844-hello/#findComment-4905834
It wouldn't happen to be an 88 or 89 model would it?
If that's your car in as your avatar picture i'm pretty sure that i can see your compliance plate in Blue. (UNless the factory skyline plates are blue, the s-series ones aren't)
If it is an 88 or 89 model than it'd be complied under the 20 year rule and doesn't need an Australian compliance plate just the factory one.
https://www.sau.com.au/forums/topic/293844-hello/#findComment-4906439
Just to clarify, no compliance plate (i.e. it came in under the 15 year rule) means a full pit inspection at Regency, regardless of whether it has been registered interstate before.
https://www.sau.com.au/forums/topic/293844-hello/#findComment-4906846
Please use the search function - this has been covered dozens of time before.
And if you desperately need to make a new thread (for some reason), please be VERY descriptive as to what your thread is about - "Hello" is completely unsatisfactory. Something like "Buying a car from interstate, help needed" would have been much more appropriate.
https://www.sau.com.au/forums/topic/293844-hello/#findComment-4909901
no prob mate
https://www.sau.com.au/forums/topic/293844-hello/#findComment-4909911
Guest
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
