ok guys, after going through my garage i found (after 3yrs) nearly new headlights for r33 skyline, series 1.
they are in excellente condition with no scratches at all... LIKE NEW
not sure about price, so if u make any genuine offer i will consider it.
or help me and advise me how much i should ask for them
PS. have seen used silvia headlights going for around $250 each
https://www.sau.com.au/forums/topic/29385-fs-skyline-r33-headlights-cheap/
  • Replies 54
Consider:
Have bought 100% brand new indicator assy. from Nissan dealership (usually higher priced) for $140 the pair.
You may have seen some fool asking $250ea for silvia headlights, but were they sold at that price?
Remember, your lights are second hand, they may be in great condition but they are still second hand.
So if you think i am not GENUINE post a price, as stated in the rules.
Alan
Series 1 Headlights usually go for $500-600/pair, and are quite rare to be seen up for sale. There is a big market for them from all the guys who smash the fronts of their cars.
You CANNOT buy these headlights for $140/pair from Nissan :cheers:
They're more like $800/pair for the series 1 headlights and $1500/pair for the series 2 headlights.
How do I know? Because I have bought Series 1 headlights new from Nissan before at trade price and quoted out the Series 2 ones, but balked at the ridiculous price.
al
1. it was not some fool asking $250 each, but couple of spare parts shops in sydney... no names
2. yes i think ur offer is not genuine at all
3. these headlights are pretty rare anyway as far as i know
4. series 1 are about $800 new, series 2 $1500 new
thanks 4 ur offer anyway
i bought a very close to new passengers side r33 s2 headlight for 250 the other week
was wondering if u wanted to let one go for 250 (passenger side one of course)
for a mate
Guest darrinspencer
al
You can buy BRAND new lights series 1 from Nissan Australia for $385 each
series 2 are about $400 each
if yours are as good as new but second hand i will offer $475 for the pair delivered to Brisbane.
any chance of some photo's
dspencer@triple-m.com.au
THey are the 4 door and fit into the 2 doors with no problems.. i have them on my car in Australia.. gives a more classy look.
wld33R .. honestly mate.. those are in v.good nick, give a call to some second hand shops and see what the price they sell. I got mine with the car, but i have asked one shop to get a quote.. i was quoted at 650 for a pair... so not sure.. mm.. maybe i got quoted a big high? *shrugs
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
