My Hicas light still comes on when I start the car. I got my power steering rack and the pump replaced not long ago and it still comes on. Could it be the Hicas pump?
Does your speedo work? If it doesn't then thats why. Lock bar will fix your problem haha.
https://www.sau.com.au/forums/topic/293877-hicas-light/#findComment-4904422
everything works just at times Ill start the car and the hicas light will stay on and my steering will be real stiff
Well if the steering is stiff then it'll be the pump or the rack again. Nothing to do with the rear hicas I don't think.
https://www.sau.com.au/forums/topic/293877-hicas-light/#findComment-4906465
HICAS is the rear steering in your car. that light can come on for numerous reasons.... if u see the light and wanna fix it, the easiest way is to disable it. R32s you remove the hicas rack completely and replace it with a lock bar. you can remove all of the hicas stuff with it. plumbing, hicas solenoid etc. R33s onwards are electric. just as easy to disable, just done differently.
https://www.sau.com.au/forums/topic/293877-hicas-light/#findComment-4908126
hicas determines speed sensitive steering. Often when hicas plays up the steering does get heavy. It happens to people who swap steering wheels to aftermarket but dont use a hicas boss kit, they all get heavy steering due to no hicas input being received to ecu.
https://www.sau.com.au/forums/topic/293877-hicas-light/#findComment-4908132
yay for lock bar and globe removal! works everytime. HICAS not needed. just adds weight. get ridda that!
that's right that's what i did light kept going on annoying so got lock bar and removed the stupid red light globe lol
https://www.sau.com.au/forums/topic/293877-hicas-light/#findComment-4911578
soo your saying if I get a Hicas Boss kit it should resolve the problem..as Ive changed the pump and rack a few mnths back and it still comes on?
nah hicas boss kit is just an adapter you need to use when you try and fit an aftermarket steering wheel.
If you have standard steering wheel ignore everything ive said :)
https://www.sau.com.au/forums/topic/293877-hicas-light/#findComment-4912125
thanks for the help mate
Ive recently changed the steering wheel and the light at times comes on about an hr of driving. As I turn the car on it the morning there will be no light..its weird
did you change to an aftermarket steering wheel?
Did you use an appropriate adapter which works with hicas? Did you have this problem before the change of steering wheel?
https://www.sau.com.au/forums/topic/293877-hicas-light/#findComment-4912678
i agree with Russ as well. I dont have HICAS in my car. i stripped everything i could. yet every so often i get heavy steering and ive rebuilt both the rack and the pump. there is a solenoid on the rack that may have something to do with it....
ill get round to it eventually
https://www.sau.com.au/forums/topic/293877-hicas-light/#findComment-4915893
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
