hey guys.. got a few things for sale:
1. oem brembo rotors + pads... rotors taken off V with 60000km. in good nic. pads still have 60% left. $150
2. oem standard v35 braking system. still on my car but will be taken off shortly.. pics will be put up soon.. incl rotors pads & calipers & lines. $500
3. oem v35 17" stock wheels + tyres.. tyres still have about 70% tread left. wheels al have gutter rash from owner in japan. more pics avilable upon request. $400
any questions dont hesitate to ask.
cheers guys,
https://www.sau.com.au/forums/topic/293920-fs-brakes-wheels/
cheers guys,
Hi mate,
How much for only STD rotors?
Cheers,
Aum
Edited by aum
