Only 3 Months use and in perfect condition, comes with, Full plug Loom and all connectors, boost control, Map sensor, Engine Map sensor switchers and plug in ECU socket for glove box location, Deletes for Twin Turbo set up, so no air flow meters needed, the Motec is unlocked and cleared and ready to go, I do not wish to separate this upgrade kit at this stage, its not being used so its time to sell, it cost me $4,660 2 years ago.
Selling for $3,900
Melb location, prefer pick up, if interested could you pls PM me or Phone Nick on 0425763096
https://www.sau.com.au/forums/topic/293931-motec-m800/
Selling for $3,900
Item still available.
https://www.sau.com.au/forums/topic/293931-motec-m800/#findComment-4909882
that loom is direct plug for factory correct?
IF so i have a m800 with a full loom not the patch loom like yours are you intrested in trade or just selling it to me.
The m800 is good for any car at all your limited to just what your loom can plug into :D
I have a 33gtr already have a motec m800 just have not bought the plug and play loom :D
let me know
https://www.sau.com.au/forums/topic/293931-motec-m800/#findComment-4910881
Selling for $3,900
Motec M800 is used by High end GTRs the world over, simply flick the switches on this one to change the tune settings, fuel blends, boost, etc, my set up had, Shell100 at 350kw@4, BP98 at 325kw high boost, BP98 at 270kw low boost and valet parking mode, now with E85 fuels, race fuels and so on, its up to you and your imagenation, dont keep getting slugged at the tune shop, do it all in one hit!
New Price $3,600 FIRM.....Great saving!!
https://www.sau.com.au/forums/topic/293931-motec-m800/#findComment-4913005
  • 4 months later...
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
