hi guys, i had my a/c on in my r32 4 door and as soon as i turned the engine off and got out of the car, i noticed it was leaking coolant.
i popped the bonnet and it was leaking out of the top of the overflow tank, can anyone explain to me why its doing it? and possibly how to fix it...
any advice will be greatly appreciated
cheers
https://www.sau.com.au/forums/topic/293963-radiator-cooloant-leak-when-ac-on/
When you fill up the coolant resouvior tank, are you filling to the indicated max line when cold, or filling halfway (between min & max) or lower?
i bought the car on thursday, and checked the coolant level in the resivoir and it was on max
well like moodles2 basicaly said when the cars dead cold. check the water level on the overflow Reservoir should say something like cold or hot. fill it up to cold when the motors cold. that should get ur correct level if overfilling is the problem. is it a standard reservoir? see how u go
yeah its a standard resovoir, but it only leaks when the air conditioner is on, when the a/c is off there is no problem it doesnt overflow, i had the a/c on for about half an hour and the moment i turned the car off, thats when the coolant started pooring out of the top of the resovoir,
i will check the coolant level tommorow and make sure its on the correct level, but im pretty sure somethings happening with the a/c
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
