RompaStompa Posted October 28, 2009 Share Posted October 28, 2009 hi guys, i had my a/c on in my r32 4 door and as soon as i turned the engine off and got out of the car, i noticed it was leaking coolant. i popped the bonnet and it was leaking out of the top of the overflow tank, can anyone explain to me why its doing it? and possibly how to fix it... any advice will be greatly appreciated cheers Link to comment https://www.sau.com.au/forums/topic/293963-radiator-cooloant-leak-when-ac-on/ Share on other sites More sharing options...
Moodles2 Posted October 28, 2009 Share Posted October 28, 2009 When you fill up the coolant resouvior tank, are you filling to the indicated max line when cold, or filling halfway (between min & max) or lower? Link to comment https://www.sau.com.au/forums/topic/293963-radiator-cooloant-leak-when-ac-on/#findComment-4905761 Share on other sites More sharing options...
RompaStompa Posted October 28, 2009 Author Share Posted October 28, 2009 When you fill up the coolant resouvior tank, are you filling to the indicated max line when cold, or filling halfway (between min & max) or lower? i bought the car on thursday, and checked the coolant level in the resivoir and it was on max Link to comment https://www.sau.com.au/forums/topic/293963-radiator-cooloant-leak-when-ac-on/#findComment-4906148 Share on other sites More sharing options...
mattie09 Posted October 28, 2009 Share Posted October 28, 2009 well like moodles2 basicaly said when the cars dead cold. check the water level on the overflow Reservoir should say something like cold or hot. fill it up to cold when the motors cold. that should get ur correct level if overfilling is the problem. is it a standard reservoir? see how u go Link to comment https://www.sau.com.au/forums/topic/293963-radiator-cooloant-leak-when-ac-on/#findComment-4906188 Share on other sites More sharing options...
Moodles2 Posted October 28, 2009 Share Posted October 28, 2009 Water expands when it gets hot, if it's at the max mark while cold, it's not suprising some is flowing out the overflow Link to comment https://www.sau.com.au/forums/topic/293963-radiator-cooloant-leak-when-ac-on/#findComment-4906234 Share on other sites More sharing options...
RompaStompa Posted October 28, 2009 Author Share Posted October 28, 2009 yeah its a standard resovoir, but it only leaks when the air conditioner is on, when the a/c is off there is no problem it doesnt overflow, i had the a/c on for about half an hour and the moment i turned the car off, thats when the coolant started pooring out of the top of the resovoir, i will check the coolant level tommorow and make sure its on the correct level, but im pretty sure somethings happening with the a/c Link to comment https://www.sau.com.au/forums/topic/293963-radiator-cooloant-leak-when-ac-on/#findComment-4906253 Share on other sites More sharing options...
tridentt150v Posted October 28, 2009 Share Posted October 28, 2009 more likely to be overheating with the a/c on. Get your radiator flushed out and new coolant put in, that will clean it up Link to comment https://www.sau.com.au/forums/topic/293963-radiator-cooloant-leak-when-ac-on/#findComment-4906412 Share on other sites More sharing options...
RompaStompa Posted October 30, 2009 Author Share Posted October 30, 2009 ok cheers trident, i shall go and get some more coolant and do that asap, cause its steering towards summer soon and i dont want to have no a/c Link to comment https://www.sau.com.au/forums/topic/293963-radiator-cooloant-leak-when-ac-on/#findComment-4909980 Share on other sites More sharing options...
indy64 Posted November 1, 2009 Share Posted November 1, 2009 it's easy to flush yourself, try using the red coolant, it might be a bit more expensive than the green though and take off the overflow bottle and flush that out as well. Link to comment https://www.sau.com.au/forums/topic/293963-radiator-cooloant-leak-when-ac-on/#findComment-4912544 Share on other sites More sharing options...
