Hey guys n girls,
Courtesy of Prank ive got my new skylineaustralia email addy .... but i dont know how to set it up in Outlook ..... weally stuck!!
Can someone please help me out with some simple instructions :(
Thanks
Lauren
:cheers:
https://www.sau.com.au/forums/topic/29398-pls-help-this-blondie-out-with-email/
Go to email accounts under tools at the top of the page, select add a new email address, this is where you need the hopefully supplied info, usually select pop3. then enter the details in the appropriate fields and test your account settings using the button supplied in this field........Viola bob's your uncle. hope this helps lovely Lauren. :cheers:
If you look on iiNet's website or similar they've usually got step by step instructions with pictures on setting up outlook express - just rememebr to replace the server settings on their website tutorial with the ones for your e-mail and you should be set :)
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
