I'm not sure if brochures have been posted on here before, or if they would be of interest but i guess i will see by posting some. As far as i know i have a copy of all of the M35 brochures/sales sheets and manuals (except original parts book - which is on its way from Japan). I have scanned the brochures into .pdf for anyone interested.
I have aero brochure, AXIS, Options catalog etc. etc.
1st instalment is the NISMO Sports Parts Brochures although they are for the PM35 Series 2.
Let me know of anything you may need and i will see if i can help...
Enjoy
NISMO_Stagea_Sales_Brochure.PDF
NISMO_Stagea_Sales_Sheet.PDF
  • Thanks 1
https://www.sau.com.au/forums/topic/293993-m35-stagea-sales-brochures-books/
Enjoy
Good find...
Enjoy
Thanks Jase.
Are you going to do the other brochures too?
Love those seats :(
Edited by iamhe77
Thanks Jase.
Love those seats :(
Yes Cam, all scanned and ready to go....
This instalment is the Stagea Aero Selection brochure
Stagea_Aero_Selection.PDF
  • Thanks 1
Thanks Iain,
There is more to come
And here is the third instalment....
Stagea Optional Parts catalog
enjoy.....
Just had a look through this one... It seems that the Carozzeria unit that is in Nickcorr's ARX and my mates blue RS was factory optioned!
Too bad I cannot find an english option for these...
Yes I was thinking the same... That would explain why it is so well installed, althought it is an 03 unit but the car is an 01, so it was not fitted new.
Looking at that brochure, loads of the little things on my car are Nissan accessories, I had just assumed that they were aftermarket.. Now if only they could have ticked the Bose Audio and cargo net boxes whilst the car was still in Japan....
Just added them up, I got JPY 518,270 of accesories on my car... Would have been about AUD 7,000 in those days..
Edited by nickcorr
hehe V.S.S. exhaust silencer. stephen (the bastard :P) has this option!
gotta fix that on your car mate so it all works again!!
the front corner cameras look cool, as does the dipping rear view mirrors. i wish the kits on IM were cheap enough!
anyone know what that little camera looking thing on the dash is? my arx (soon to have) has it...
Its on the Driving Support page above the Security System and next to the folding mirrors.
I'm guessing its a internal screamer siren or movement sensor....
sounds like a good guess to me.
Looks like a motion sensor upgrade for the alarm...
I have the rest of that pack installed on my AR-X with the auto folding and dipping for reversing mirrors.. Both really cool and useful.
How does one get the auto folding & dipping ones. .. mine only fold when the button is pushed. .
is there a kit. .
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
