Pits Tomorrow What To Expect....
GODZ1LLA
 Share
  • Replies 68
Mine extends when I turn the radio on and retracts when I turn it off.
Yeah there is a switch for full aerial hight and half aerial height. You can't have the option of no aerial at all unless you disconnect it :/
haha man I get so confused with this guy. When you got the stereo on, flick the switch to the left of the steering wheel down and it will retract to about 30cm in length and will stay like that until you turn the car off. If you flick the switch up it will be like a metre lol
AH WTF - NO
what grade is your tint - if it's "close" to 35, get them to recalibrate the machine. most the times these things are out. my first reading was tint @ 20%
told him to get effed got his manager to recal the machine - second reading was @ 34% light omittance.
so if your tint is illegal dark then pull it off, if not, leave it and make sure u know your rights and legalities with this one.
tint = effing expensive to replace, so if u can get around it - do it.
I had 2 differant palces give me the same reading (20%) so i just ripped it all out carefully :D
doesnt look as good but i didnt pay for the tint i just wanted my pass on the pits!!!
Gonna get em re-done though, to legal grade tint in the future though :P
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
