When you go over a bump and the G's force your foot down further on the throttle, the car speeds up/lurches, foot comes up, then down in this horrible lurchy/jerky acceleration/deceleration of repeat, repeat, until to lift your foot off. Some sort of positive feedback or something going on?
I'm finding this happens more now I've stiffened up my suspension and put stiffer sway bars on.
It tends to happen at certain intersections in 1st or 2nd gear.
Kind of embarrassing.
Anything I can do?
https://www.sau.com.au/forums/topic/294013-what-do-you-call-it-when/
  • Replies 50
Lol how fast are you going over said bumps? Because if you are going fast enough for the G-forces to push your foot down, i really wouldn't be worried about the embarrassment of lurching lol...
Hmm not that fast, but I've been driving a bit more 'uninhibited' now I've got some mild mods.
I've had my foot totally on the floor a few times lately just to test the car out. :( Within the speed limit of course and with no loss of traction. :rofl:
I don't think he means speed bump, just any bump... I can't say i have experienced this though lol. Maybe i have, but i wouldn't describe it the same way as you haha. Don't really understand
Yeah not speed bumps as such, I don't go over them fast. I mean just the bumpy/poor surfaces of intersections etc.
We've got some real cr@p roads here in Perth that is for sure.
Yeah taking your foot off the gas until the car settles seems to work, but this seems to mean that with some traffic lights/intersections you just can't do a 'hero' type launch....er hypothetically that is. :( I guess that is the prices of stiff suspension for good cornering?
hehe, i know wat you mean, my aristo has fairly stiff suspension and this happens to me wen i drive over bumps n stuff, i have found letting off the gas until the car settles is your best bet!!
You just answered your own comment there, your aristo (read barge) is so bloody heavy it NEEDS stiff suspension to eliminate all the commodore like bodyroll.
As for the lurching, what sort of clutch do you have? How much play do you have with your release point etc? Might just want to give it a few move revs before you engage the clutch. Your suspension doesn't have anything to do with how you're using the clutch :(
Fair dinkum guys, he's not talking about jerky clutch take offs.
He's talking about going over a bump and that bump translates into his foot moving slightly on the throttle.
Rysies, why would you clutch in when rolling through an intersection? if anything you'd just lift off the gas or just raise your heel off the floor.. that's what I do, especially over railway tracks.
Hmmm i think i get it, seem to remember this happening when i was first on my L's... No offense intended with that lol. Just that in my first car i learned to do what these guys are saying, balance your foot on the accelerator and make sure your heel isn't on the floor.
In the Skyline it doesn't happen to me anymore because i make sure to not go over said bumps lol, ive replaced one rim already from Perth's sweet road surfaces, making sure it doesn't happen again
He's not talking about speed bumps, he's talking about shitty roads with holes and bumps. Don't worry mate, it is a normal by-product of stiff suspension. All your controls become extra sensitive as a result. Bumps make you lose traction very easily too. As for taking off from the lights, you can either:
A. Wedge your foot against the kick panel so that it is less likely to move when going over bumps
B. Lift off throttle and just coast in gear or use a bit of clutch over the shitty parts of the road to turn power on/off. Or if in a drag race...
C. Foot flat to the floor and let an LSD take the blame.
With my coilovers I don't bother with traffic light heroism on shitty roads, particularly uphill...you'll just get messed up in 1st gear.
I've read this thread a few times for shits and giggles - the guy can't drive his car.
I've got stiff suspension, a monster clutch and the roads around here are f**ked, maybe I'm just used to it but I have no drama's, my driveway is even worse and I can reverse up that without spitting gravel. I didnt get my license from the bottom of a Fruit Loops box..so I dunno.
You've read it a few times and still didn't know what he was talking about?
How about you shut up now.
Edited by bubba
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
