1995 Nissan Skyline R33 GTS-T white
190XXXkms
Engine rebuilt at 164XXXkms
230KWSATW (ESP Racing Dyno)
-Garrett T3/T4 turbo (on high mount manifold) with external 38mm Turbo Smart wastegate, 4 inch dump pipe, 3.5 inch system with 5 1/2 inch cannon. Great note.
-Blitz blowoff valve plumed back,
-bigger intercooler with piping
-600hp walbro internal fuel pump,
-Injectors (Guys from ESP Racing told me they arn't limited and i'm unsure what size they are)
-Mines ECU
-Strut Brace
-DVD player, 4 X 6 inch JVC speakers, 15 inch sub and 1800 watt amp
-3 piece rims Front 235/ 45 17 and read 255/ 40 17 tyre 80% tread.
Victorian Rego until Jun next year
$13000 ONO
Nick : sms 0408513746 or email me [email protected]
https://www.sau.com.au/forums/topic/294028-1995-r33-gts-t-for-sale-cbr/
It is located in Canberra.
A few things i forgot to mention.
-Spitfire Coils
-Aftermarket Fuel Pressure Reg
-Head bolts replaced with studs
-Head was replaced for a better flowing one
When rebuilt found out it had been bored 0.5 thou oversized
I'm selling it to buy a RS260 and there are 2 that i'm looking at. Just something that will have more room and i'm starting to get sick of 2 door cars as thats all i've had. I dont see why it wouldn't pass an ACT roadworthy.
I have forgotten to mention it has a Exedy single plate heavy duty clutch as some chick was driving my car and stuff it.
Its a great car and I've had lots of fun with it.
I have never been able to take it on the track or down the strip.
  • 2 months later...
  • 3 weeks later...
  • 3 months later...
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
