Wrecking S1 R33 Gtst Left Overs, Geelong, Vic
  • Replies 56
hey buddy im after the following stuff if u got pm me back if ur cool with the offer too:
> In-cabin driver-side Fuse box cover.--->$5
> OEM BOV in excellent condition with no leak---->$20
> LHS Mirror (whole lot if in black paint)---->$40
> Stock Turbo in good condition----> $??
> Steering wheel if still in good nic ---->$25
> Handbrake handle if still in good nic---->$5
cant edit first post so i guess i'll chuck some prices up for the main things....all these are ONO as im just making them up
near perfect dash pad with most of the dash plastics $50
decent carpet, just needs a clean $10
complete heater/aircon unit $20
washer and overflow bottles $10
shell has a good drivers side rear quarter $50
good complete passengers side door, door trim is average $150 looks to be sold though
near perfect taillights $50 a side for complete lights
perfect rear bar $50
good boot with wing, wing needs a bit of bog/fibreglass $50
aircon pump $20
front crossmember and rack, crossmember might be bent $30
front 5 stud hubs and uprights $50
good headlining $10
ignition barrel with key $50
stock castor arms $20
rear half of tailshaft $10
stock cooler piping $20
fuel tank with filler, no pump $10
rear cradle with lsd and shafts, no brakes or hubs $150
3-3.5in cat back exhaust, single straight thru muffler $100
stock front shocks with hks lowered springs $50
also have non r33 stuff
pair of S15 stock mags $50
pair of 300zx stock mags $50
both painted black with crappy spray cans, would come off prety easy
full set of 300zx brakes and rear 5 stud hubs
front has: calipers, pads, lines and rotors...took pics but they disappeared
rear has: calipers, pads, lines, rotors, 5 STUD HUBS and handbrake cables
$600
also got some alloy 300zx/GTR rear upright things (what the rear hubs bolt to) $100 just been bead blasted so look like brand new
sorry for the slow replys, still got no modem
dnggskyline, still got everything thats in the dash pics at the start of the thread
Darkryda, PM sent
probably best sending me a txt with what you want as the PM system on here takes too long to write back to everyone in the time i have on the computer
0438023584
cheers
Nick
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
