  scrantic said:
How do the KU36's go in the wet? I'm after a daily driver tyre mostly. I have RE050A's @ the moment that have lasted me 49,000k so far from new. Great tyre but for $375 a corner its too much to justify.
Got a Quote of $275 for 215/45/r17 Adrenalins or $225 for the KU36.
RE001 will last shitloads longer, and you might want to shop around. Try Craig at Trackside, he is normally pretty good on price.
KU36 also need a bit of heat in the hills, RE001 not so much.
KU36 noticeably worn after ~5drives, RE001 I have gotten 40k km + out of
EDIT: didnt read the following:
  scrantic said:
OK so just rang back to book it in, Adrenalins 215/45/R17 are on special for $225 and 225/45/R17 $250
thanks for all the replies guys
he has booked it in for new tyres tomorrow
so all sorted
the wrx is a nice car to drive
i miss a standard clutch when driving his car
the headlights are amazing vs r33 = hopeless
my clutch and clutch pedal is hopeless vs stock :(
  Jack- said:
I just bought a set of Bridgestone potenza adrenalines.
245/30
265/45
i think something like that $350 for each front and $500 for each rear.... worth every penny, grippy as f**k and awesome in the wet
um that's a lot of sidewall at the back and not much at the front, you sure that's right? if so your going to have a fair bit of rake going on...
well its pissing down today and the KU36 are struggling... I'm not sure if its just the roads are greasy cos it hasn't rained in a while but they're having a bit of trouble putting down zee power... the attessa helps out but the rears still break away really easily... the car makes a fair whack of power so I don't expect miracles but they aren't the best wet weather tyre out there
Agreed, same experience for me today on same tyres of about the same age. OK, but not great. I'm in RWD car though with heaps of RWKW.
360kw atw here... it just wants to walk around and spin all 4... my old GTSt with 260rwkw actually put power down in the wet better than the GTR... mostly due to much softer rear suspension, less power and more linear boost curve... but it also had Hankook K107's which I rate highly, really good tyre too
KU36 good dry tyre though, I can shift 1-2nd at 8000+rpm really aggressively and it just grips and goes... it fully chirps 2nd... fully
KU36 are fine on wet roads, but shit on greasy roads if that makes sense....
but in the dry with some heat in them :blush: i have baby power compared to all of you, but I used to have traction issues, and Now I can use first, second and third :ninja:
I don't really rate the Adrenalins that much. I had them on all fours but now only running them on the front with Kuhmo on the rear. At best the RE001 is average in the wet, no where near the amount of grip I got from Eagle GSD3
mate i know that the ku36 are pretty cheap but they are rated very low in terms of life. they are budget sticky tire and as a daily driver you won't be able to get many km out of them.
i put ku31 on my car as i regularly track it and its a daily(was running ventus k104 before) and find that they are doing fine. i found a bloke that does the ku series tyres in richmond and paid 150 i corner (r17 234/45) and he was the cheapest i could find. about 70 bucks cheaper each!
i think its advanced tyres next to ikea, pm me if you need the exact details and i will fish through my reciept book
  tets said:
anyone know prices on advan ad08s they released in australia now soo not as pricy as the ad07s
ad08's are drool worthy. If they weren't about double the price of the KU36's, i'd get them in a heart beat. I had ad07's on my old set of AVS Model 5's, 17's. Such an awesome tyre. Bit noisy but man, grip central. The AD08's just look awesome though. Traction Tyres has a STACK of them in their place... so demoralising :down:
$500 per corner i was quoted at TT for 265/35/R18
For reference, as the OP has already sorted everything out, i got KU36, 245/40/R18 fitted/balanced for $1132. Solved my traction issues from the old bridgestones and held up fine at Sandown a couple sundays ago.
^^ indeed. i'm surprised no one has really recommended them but then i guess they are quite bloody expensive. had neova ad07s on my rear meisters on my last 32 and these things would not let go at all in the wet or dry. most likely the best tyre i've had on any of my cars. never noticed the noise but my exhaust was louder so don't really care lol.
