I dont want to get bitched at for spreading false info so... disclaimer: I think the following is correct but I'm not 100%.
Compression test: Tests the amount of compression in a cylinder by screwing the device into a spark plug hole.
Intercooler: This isnt mine :cheers: ---> "A device which cools the air entering the carburetor or fuel injection system. Colder air has more oxygen molecules than warm air. Thus cooler air gives more power and better fuel economy. An intercooler looks like a radiator. It contains large passages for the intake flow, and uses either outside air or water directed over it to lower the temperature of the intake flow inside. Also called a "charge-air cooler" or "chargecooler." Compare "aftercooler." "
https://www.sau.com.au/forums/topic/29405-noob-questions/#findComment-601444
As Sumo said, it is a test that involves removing a spark plug, and inserting a 'compression' measuring dial and cranking the engine over. This forces the piston to compress, (but not there is no ignition).
The pressure can then be seen on the dial before it dissipates. If the piston rings are shagged, then the compression will be poor. Good compression is important for a healthy engine, and you can find out the required compression for your engine from workshop manuals.
https://www.sau.com.au/forums/topic/29405-noob-questions/#findComment-601772
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
