  • Replies 61
Just make sure he doesn't have a stage 8 auto transmission, because if he does you're gonna be flat out of luck. Those things are animals with this upgrade. Do you know what he has under his bonnet? I think you should get a couple of parts from Japan before taking him on.
Dude, OVERNIGHT parts from Japan, and a Motec Exhaust to say the least. I'd probably re-enforce the floor plan because they've been known to come loose when you're manifold pressure is to high. Keep it to 5 shots yeah?
i hear MoTec are releasing new turbo back exhausts designed specifically for 33GTST's that will be doing drags. they say gains of up to 45RWKW are easily achievable with stock turbo. try google'ing that shit brah
I'm assuming you'll be "racing" at Calder on Friday night yes?
Yeh thats what he said Calder,still have a couple uv weeks before i take him on.so wil put a few things in the line.at the moment i got a Blitz Fmic,nismo turbo back,what else do u reckon should i get?
Oh ok, so this will be a legal race...in which case I'll give you a serious answer:
Get a bleed valve / manual boost controller; don't run much more than about 11psi. If you get a chance do some supporting mods like a front mount intercooler and exhaust system.
Those crossfires are pretty quick (they sound awesome too). You can match one with an exhaust system alone but you will need to be perfect in your shifts and launch.
^^ Brids, he already has a FMIC and turbo back exhaust. :)
Boost controller is the next step then maybe a tune, get an APEXi Power FC...
Upgrade your Panel Air Filter to a high flow one, like APEXi, K&N just to name a few... Or you got an air pod?
I never new the Crossfires where that fast...
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
