  • Replies 61
^^ Brids, he already has a FMIC and turbo back exhaust. :)
Boost controller is the next step then maybe a tune, get an APEXi Power FC...
Upgrade your Panel Air Filter to a high flow one, like APEXi, K&N just to name a few... Or you got an air pod?
I never new the Crossfires where that fast...
mate i got a HKS pod filter, seriously bro dont know anything about crossfires its just one of my
friends he has an r34 and his girlfriend just bought a crossfire he drove it and said they are good.
thats y i was a bit concerned.Getting a manual boost control next week, Powers FC is next on the list
its just ma pocket is holding me back this month, was looking for a second hand over here but can seem to find 1 for a good price
still searching
powerfc, injectors, gt35 internal gate, exhaust manifold spacer, z32 afm, 22psi boost.
gogogoog
why just beat him when you can completely annihilate him
Agreed.Thats what am gona do still have time ill put all the godies in my line and then take him to Calder
What he just mentioned is about 5 GRAND or more worth of gear.... not to mention clutch and tyres etcc...
u'd be getting close to $10,000 ...
so at the end of the day...is it worth it?
just asking(and assuming)...do u have a small package or something and need to show ur a man?
u've got the basic stuff... buy a $50 manual boost controller and get some more boost... if he wins hes no better or worse a bloke then you...
just remember that when your laptop says "danger to manifold"
SLAM it shut and tell it to shut up!
you'll run 10's
srsly tho.... crossfires are slow as... a 33 with basic mods will munch it
thats not a thing mate i respect all racers its just if some challenges you u cant step back :thumbsup:.
i boutght the car 2 months back i got it for just one reason ill maki it a fast gtst.cant do it all at once but the guy challeged me at the wron time but still have to keep
upto mark :)
Rent my car for the race. Its being Scoutered to have a power level of over 9000!!!!
Also comes with a different buttons for different stages of turbo boost transformation to boost the power further from 9,000+ to 12,000 to 18,000 to 21,000 to 24,000+
Crossfire have a 0 to 100 time of ~8 or something?
Edited by Mayuri Krab
you'll run 10's
ur right bro its just didnt wana munth it want to swallow it :).so have to do a bit uv mods. :thumbsup:
You are correct my brother man. It is just that I did not want to simply masticate said crossfire, but digest it entirely. I do believe I will require modifications to my automobile.
huh?
:thumbsup:
Check this out. It will give u ideas
(POSITIVE)
0 to 100 6.5sec
It can reach 150+ MILE flat. 250kph
Check this one out (NEGATIVE)
Top gear
Well i reckon u can beat it if u know how to launch it!
Edited by tavstar34
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
