  • Replies 61
^^ Brids, he already has a FMIC and turbo back exhaust. :)
Boost controller is the next step then maybe a tune, get an APEXi Power FC...
Upgrade your Panel Air Filter to a high flow one, like APEXi, K&N just to name a few... Or you got an air pod?
I never new the Crossfires where that fast...
mate i got a HKS pod filter, seriously bro dont know anything about crossfires its just one of my
friends he has an r34 and his girlfriend just bought a crossfire he drove it and said they are good.
thats y i was a bit concerned.Getting a manual boost control next week, Powers FC is next on the list
its just ma pocket is holding me back this month, was looking for a second hand over here but can seem to find 1 for a good price
still searching
powerfc, injectors, gt35 internal gate, exhaust manifold spacer, z32 afm, 22psi boost.
gogogoog
why just beat him when you can completely annihilate him
Agreed.Thats what am gona do still have time ill put all the godies in my line and then take him to Calder
What he just mentioned is about 5 GRAND or more worth of gear.... not to mention clutch and tyres etcc...
u'd be getting close to $10,000 ...
so at the end of the day...is it worth it?
just asking(and assuming)...do u have a small package or something and need to show ur a man?
u've got the basic stuff... buy a $50 manual boost controller and get some more boost... if he wins hes no better or worse a bloke then you...
just remember that when your laptop says "danger to manifold"
SLAM it shut and tell it to shut up!
you'll run 10's
srsly tho.... crossfires are slow as... a 33 with basic mods will munch it
thats not a thing mate i respect all racers its just if some challenges you u cant step back :thumbsup:.
i boutght the car 2 months back i got it for just one reason ill maki it a fast gtst.cant do it all at once but the guy challeged me at the wron time but still have to keep
upto mark :)
Rent my car for the race. Its being Scoutered to have a power level of over 9000!!!!
Also comes with a different buttons for different stages of turbo boost transformation to boost the power further from 9,000+ to 12,000 to 18,000 to 21,000 to 24,000+
Crossfire have a 0 to 100 time of ~8 or something?
Edited by Mayuri Krab
you'll run 10's
ur right bro its just didnt wana munth it want to swallow it :).so have to do a bit uv mods. :thumbsup:
You are correct my brother man. It is just that I did not want to simply masticate said crossfire, but digest it entirely. I do believe I will require modifications to my automobile.
huh?
:thumbsup:
Check this out. It will give u ideas
(POSITIVE)
0 to 100 6.5sec
It can reach 150+ MILE flat. 250kph
Check this one out (NEGATIVE)
Top gear
Well i reckon u can beat it if u know how to launch it!
Edited by tavstar34
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
