Check this out. It will give u ideas
(POSITIVE)
0 to 100 6.5sec
It can reach 150+ MILE flat. 250kph
Check this one out (NEGATIVE)
Top gear
Well i reckon u can beat it if u know how to launch it!
those videos helped alot especialy the one that was negative haha. i dont get one thig a stock
R33 is 184 KW but i dynoed my car and the max power at 7 psi (standard) it gave me 154.Any
idea y was that.i have a FMIC and a full Nismo Exaust.
  • Replies 61
are you talking about stock vs stock
or are you talking about mods as well?
if your talking about mods then exhaust, intercooler, tyres, boost controller, ecu, boost to 12psi and a good tune
will beat him no problems, youll be surprised what a mild gtst can beat with a good driver
if your talking stock and no mods then drop tyre pressure (dont keep it at 40psi) in the rear
learn how to drive and how to launch and go for it, your best bet is to out-launch him (dont rev to 5k, but above 2k) and go from there
turning up the boost on a bog stock gtst will add a touch more power, but its far from making the car twice as quick going from 5psi to 11psi
the stock exhaust, ecu, tune, intercooler, intake will hold the car back a bit even with more boost stuffed in
stock gtst will do 140rwkw on the dyno and with a touch more boost you might get lucky and see 150rwkw
the crossfire you posted makes less power, but more torque
it depends on how heavy it is as well and the skyline is around 1400kg so check its weight
the crossfire might have more average power (sounds like it) vs the skyline
but the skyline has good diff gears which gives it great acceleration
My R34 destroyed a manual Crossfire. By the time i was in second he was a car length behind... and 3rd just kept pulling.
It had an exhaust and 12psi.
That however was the non-supercharged version. What version has this guy got. The charged ones do 12s pretty damn easy
Thanx for the advice mate.yeh its just the launch that stuffs me up some times i mean the car just spins out will practice on my launch,
am alrite with the shifting part.well ill get a boost control next week. i already have a FMIC,Exaust,HKS POD and a High Flow Cat.
i dynoed it a month back and it gave me 154 KW at the wheels on standard boost.
dono if its a super charged version will ask him,probability is its the non-supercharged version
R33 GTS-T's had an air feed to the stock air box right..?
If you still have the stock air box, you could just bolt on the air feed (Cold Air Intake / CAI) to feed air to the HKS Pod, that will help with a bot more air...
wow dude u need to get some boost up, POD and then i nice tuned.
Mods i got on my r34 is (3 inch) full zorst, Pod, 10 psi and a tune. 180rwkw
FMIC and fuel pump is next soon for me. and abit more boost ofcorse (12 psi) hehe
....the crossfire you posted makes less power, but more torque
~1440kg
Guys - pods ARE a wank, all they do is make noise and make your car illegal if you're running a FMIC. The difference in power would be so minimal you'd not even notice it. Just get a high flow panel.
sounds good. So does it still make the noise or i have to put a BOV in..
I tend to disagree - If you have a CAI with a POD AND a source/duct for some cold air, then the pod will do a better job then the stock airbox.
btw - the dudes making 154rwkw with a full exh/fmic/7psi??? Isnt that a tad low? Give her a full service and throw in some new plugs. Check the base timing as well.
Reason why i say that, I made 175rwkw with just a catback and an Apexi pod and peak 9psi. Not comparing - just saying that it sounds a tad low.
yeh thats what i thought aswell,well its up for servicing next week.getting the boost controler aswell
so lets c what it gives me after that.i guess i need a proper tune, cuz some times it backfires,not exactly
a back fire more like a POP
If he's running stock boost (7psi?), an exhaust system plus a front mount would rightfully yield about 154rwkw. Front mount intercooler is more of a support mod for higher boost level rather than resulting in a power increase after install...if you don't up the boost you aren't going to see a great deal of benefit from it. Remember that the R33 RB25DET produces 184kw stock at the fly...at a drivetrain loss of say 25%, we would see circa 138rwkw. So 154rwkw sounds on target to me with those mods.
Ultimategtr has an R34, with the NEO engine producing 206kw at the fly and about 155rwkw in stock configuration. An exhaust system and 9psi would rightfully yield another 20rwkw or so.
Then throw in factors like the age of the cars, engine mileage, dyno differences etc.
:P .am getting a manual boost controler.if i set it up to 11 and leave it on 11 all the time
would it make a difference.cuz i have heard the digital boost controlers give you problems
in showing the actual boost?
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
