Garage clean out:
all the parts off 1995R33GTST M-spec (done 65000km)
RB25DET 5SPD Gearbox with near new Excedy clutch $2000
Tanabe coil over suspension $1200
left hand Door $400
boot $250
rear spoiler $150
Rear tail light $500
mirror $200
rear bumper $150
rear seat and trim $300
F+R brake with hub (new endless pads) $1200
right hand gurd $150
right hand head light $250
Radiator $150
Aircondition (come with everything) $300
ABS brake $200
Fuel tank $150
speedo $300
more other parts not list,plz pm me the parts u want and the offer!!
R32GTR STD speedo $200
GTR aftermarket down pips new $400
located in QLD
https://www.sau.com.au/forums/topic/29408-r33gtst-parts-fs/
  • 4 weeks later...
I am interested in buying a new motor for my electric window on my drivers side door. I see you are selling the left side door. Would the motor for the electric window be the same for either side. Mine is a 95 r33 gtst series 1 so no probs there but just worried if left hand electric window motor will be different to right hand electric window motor.
If so i would be interested in purchasing it.
https://www.sau.com.au/forums/topic/29408-r33gtst-parts-fs/#findComment-628670
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
