I lowered our S2 RS Four S a few weeks back and i thought i might post up some pics and part numbers to save you guys the troubles if you are looking for some lowered springs.
I used lowered springs with the standard shocks and the car now looks as you see it below. it has actually settled just a little lower on the front than in that pic.
the King Spring part numbers i used were;
Front - KDFL-101SL
Rear - KDRL-102
Hope someone finds this useful
...Cheers Andy
BEFORE Sorry about the Blurry pic
AFTER
https://www.sau.com.au/forums/topic/294084-lowered-the-stagea-s2-rs-four-s/
Looks good man... only thing its crying for is some bolt on wheel spacers to give you a more agressive offset then it would be mint!!
yeah spewing about the offset, but the wheels came with the car and my wife drives it most of the time anyway so a higher offset = less chance of gutter rash.
if spacers were legal i'd think about it.
dont know the spring rates but i am very happy with them, not too stiff, doesnt hit the bump stops, a comfortable ride, the car is daily driven by my wife and is planned to carry our kids when they come along, and it will be fine for that.
for the supply and fitting of three full sets of springs ( took them a while to get it right, ...fussy customers lol :( ) and a 4 wheel alignment set me back $600
All work was done at;
Wholesale Suspension
129 Coreen Ave Penrith
02 47212112
couldnt recommend them more highly, they spent days sourcing and trying different springs until they got it to the height i was after, and still only charged me the normal price. They also fitted the rear camber arms i supplied them with for $240 on a separate occasion.
The fronts should be the same, Michael, but the rears may be different because Andy's car is a factory manual.
i would assume they would be the same, only thing different between them is the auto having eye bottoms and the manuals having forks. other than that, same same
Using different springs is a low cost way of improving the look with a lower stance but it will have minimal effect on the handling. If this is taken into account a slightly more expensive option is to use Bilsteins (recond to save money) to lower the car on the standard springs while significantly improving handling.
What are the spring rates?
Have these springs in front of my s1 stag well the kDFL-101 (low) ones anyway because they have a higher spring rate than the super lows.
This may help people
standard stag front spring rate is 165lbs
standard rear springs rate 170lbs linear (not progressive like kings)
kings KDFL-101 front 180lbs super low fronts only have a spring rate of 140lbs this is to allow fore more compression as the super lows and lows spring lengh is exactly the same and the springs that are any shorter cant be used as they are not caged in the strut and will float around (not safe)
not 100% sure on those rear spring rates but I would presume they would be around 180lbs to 200lbs
another option for the rear may well be KDRL-87 200lbs spring rate (z32/300zx) tapered spring (88mm-77mm)
the king springs are available from auto pro for $150 per pair :/
summing up they do work but not 100% ideal because when lowering a 20 to 30% increase is more ideal stag front springs would actually be an upgrade for an a
R33/34
My question is ?? those R32 rear springs that were used are they tapered??? they must be otherwise they would rub! any idea of the taper?? ;)
My question is ?? those R32 rear springs that were used are they tapered??? they must be otherwise they would rub! any idea of the taper?? :/
I recently bought a set of Sydneykids bilsteins for the stagea. He no longer has any of the custom made springs he was selling and told me to buy the kings as they where the next best/closet match
I will be removing my rear r32 gtr kings springs tomorrow, so I can measure them for you.
did you end up selling your old pair? could always swap the springs over if you haven't
I have someone lined up for the old shocks. New ones are on order with SK
I am keeping the springs for the new shocks :/
for the supply and fitting of three full sets of springs ( took them a while to get it right, ...fussy customers lol :D ) and a 4 wheel alignment set me back $600
02 47212112
You'll have to come past and let me feel the ride, but sounds the goods....
But now i think i know what i want from santa this year teehehe! :P
I also just finally lowered my RS4-S - Went to BC Coilovers in the end
(I also have 1inch bolt-on spacers front and back)
BEFORE
AFTER
what is your wheel widths and offsets?
any scrubbing with the spacers fitted?
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
    • Evening all. Got this odd issue with my R34 GTT. If I let the car idle for around 15 seconds or more (even when cold) and I jab the throttle a bit, a decently sized plume of blue/grey smoke comes out the exhaust. Doesn't smoke when idling alone, just when giving it some gas after idling. No smoke on cold start or from what I know, normal driving. Not 100% sure about smoke on decel but I don't think there's any. Any pointers on what I should start doing to troubleshoot it? Or if anyone has experienced the same I'd love to get some insight. Cheers.
