I lowered our S2 RS Four S a few weeks back and i thought i might post up some pics and part numbers to save you guys the troubles if you are looking for some lowered springs.
I used lowered springs with the standard shocks and the car now looks as you see it below. it has actually settled just a little lower on the front than in that pic.
the King Spring part numbers i used were;
Front - KDFL-101SL
Rear - KDRL-102
Hope someone finds this useful
...Cheers Andy
BEFORE Sorry about the Blurry pic
AFTER
https://www.sau.com.au/forums/topic/294084-lowered-the-stagea-s2-rs-four-s/
  SHIZNT said:
Looks good man... only thing its crying for is some bolt on wheel spacers to give you a more agressive offset then it would be mint!!
yeah spewing about the offset, but the wheels came with the car and my wife drives it most of the time anyway so a higher offset = less chance of gutter rash.
if spacers were legal i'd think about it.
dont know the spring rates but i am very happy with them, not too stiff, doesnt hit the bump stops, a comfortable ride, the car is daily driven by my wife and is planned to carry our kids when they come along, and it will be fine for that.
for the supply and fitting of three full sets of springs ( took them a while to get it right, ...fussy customers lol :( ) and a 4 wheel alignment set me back $600
All work was done at;
Wholesale Suspension
129 Coreen Ave Penrith
02 47212112
couldnt recommend them more highly, they spent days sourcing and trying different springs until they got it to the height i was after, and still only charged me the normal price. They also fitted the rear camber arms i supplied them with for $240 on a separate occasion.
  GoldZilla said:
The fronts should be the same, Michael, but the rears may be different because Andy's car is a factory manual.
i would assume they would be the same, only thing different between them is the auto having eye bottoms and the manuals having forks. other than that, same same
Using different springs is a low cost way of improving the look with a lower stance but it will have minimal effect on the handling. If this is taken into account a slightly more expensive option is to use Bilsteins (recond to save money) to lower the car on the standard springs while significantly improving handling.
  ステージ said:
What are the spring rates?
Have these springs in front of my s1 stag well the kDFL-101 (low) ones anyway because they have a higher spring rate than the super lows.
This may help people
standard stag front spring rate is 165lbs
standard rear springs rate 170lbs linear (not progressive like kings)
kings KDFL-101 front 180lbs super low fronts only have a spring rate of 140lbs this is to allow fore more compression as the super lows and lows spring lengh is exactly the same and the springs that are any shorter cant be used as they are not caged in the strut and will float around (not safe)
not 100% sure on those rear spring rates but I would presume they would be around 180lbs to 200lbs
another option for the rear may well be KDRL-87 200lbs spring rate (z32/300zx) tapered spring (88mm-77mm)
the king springs are available from auto pro for $150 per pair :/
summing up they do work but not 100% ideal because when lowering a 20 to 30% increase is more ideal stag front springs would actually be an upgrade for an a
R33/34
My question is ?? those R32 rear springs that were used are they tapered??? they must be otherwise they would rub! any idea of the taper?? ;)
  rx7gt said:
My question is ?? those R32 rear springs that were used are they tapered??? they must be otherwise they would rub! any idea of the taper?? :/
I recently bought a set of Sydneykids bilsteins for the stagea. He no longer has any of the custom made springs he was selling and told me to buy the kings as they where the next best/closet match
I will be removing my rear r32 gtr kings springs tomorrow, so I can measure them for you.
did you end up selling your old pair? could always swap the springs over if you haven't
I have someone lined up for the old shocks. New ones are on order with SK
I am keeping the springs for the new shocks :/
for the supply and fitting of three full sets of springs ( took them a while to get it right, ...fussy customers lol :D ) and a 4 wheel alignment set me back $600
02 47212112
You'll have to come past and let me feel the ride, but sounds the goods....
But now i think i know what i want from santa this year teehehe! :P
  Unbalanced said:
I also just finally lowered my RS4-S - Went to BC Coilovers in the end
(I also have 1inch bolt-on spacers front and back)
BEFORE
AFTER
what is your wheel widths and offsets?
any scrubbing with the spacers fitted?
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
