how much is a cams licence for 6/12 months any ideas? Do I need to be a member of SAU NSW to get a CAMS licence ? Cheers I'm definately interested in this especially as it's a driver training day (and it'd be my first track day) but being a wednesday I'm not 100% I'll be able to make it.
heyyo - 12 months licence for a l2s cams licence is about $90 and you do need to be a member of a club like sau nsw... but you don't need any of that crap for this day... just rock up with your drivers licence and drive!
im thinking about whether I can afford a new set of tyres before this day......im driving on square tyres after the last one and a few lock ups lols..... death wobbles ftw!
  • Replies 45
that's the thing, don't have a drivers licence ATM :happy: Can anyone confirm or deny if a cams licence will be enough for this day ??
Oran Park does not hire helmets you can buy them for about $100-150 at any motorbike shop.
You don't need a cams license, just your regular drivers license.
How many spots left Fatz? I really want to do another OP day but also hate taking days off work :)
if you cant splash 200 on a track day sell your car casue its the cause of your poverty
you fags!
poofs
fags
no really your all fags
just kidding!!!! :laugh: :laugh: :laugh: :laugh: :(:):banana:
your all still fags
I is no fag!
But the factor of the car being my reason for poverty is correct... ROFL
Trying to buy more parts for it... :)
um can you get a daily cams as a guest without sau membership? no I dont have a NORMAL DRIVERS LIC ATM
Get Petey Sweety to give you Aaron McGills number, speak with Aaron, he may let you run with only holding the actual licence, even though you're suspended... Just call and ask.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
