Wondering what IACV % should be? Had my car hooked up to a scantool the other day & IACV was at 100%. Doesnt seem right (although not sure) & Im having MAJOR problems with my car (7ms injector pulse at idle) so wondering if this could be the problem... Any help appreciated
https://www.sau.com.au/forums/topic/294102-what-should-iacv-be/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
