I am going to pick my car up from the tuners this weekend. He says mechanically it came up a treat, but he doesn't like my 4.9:1 ratio R180 LSD at all, on the grounds that the car wants to spend all its time up at a really high rev range, and so it isn't making the most out of it's torque. I don't like the idea of losing acceleration, but he says the diff isn't making the most of the engine's potential anyway.
He's pushing me to convert a 3.9:1 diff to LSD, arguing that his Datsun 1600 ran out of legs on the Phillip Island straight using a 4.4 ratio. His diff builder does the conversion surprisingly cheaply.
The car is a Skyline C210 sedan, with L28, triples, (making maybe 150hp?) marginally lighter than the 1210kg standard. It has a SR20det 5 speed, with the following ratios (I think):
1st: 3.321
2nd: 1.902
3rd: 1.308
4th: 1.000
5th: 0.759
I would like it to remain a quick streeter, that can do the occasional track day with the NDSOC club without being totally put to shame.
Any ideas? 3.9, 4.1, 4.4, leave it alone...
https://www.sau.com.au/forums/topic/294114-which-diff-for-l28-skyline/
4.9???
That sounds like a NISMO ratio or the front diff from a 720 4x4 (or were they 5.1's??)
L28 with triples - go for a 3.9 or maybe a 4.1 (3.7 would probably be a bit too tall - 3.54 was too tall for my old L28ET MR30, but man it had some legs!)
I'd expect that a 3.9 would be the standard ratio for the C210 anyway (it was on the MR30)
4.9 is more like the sort of ratio for a rally car - rapid acceleration out of corners, keep the engine up near peak torque.
I reckon something like the 4.1 ('74-on 180B SSS had this ratio) would be a good compromise between acceleration and top speed.
Yeah, go for the 3.9. You've got the same set up as me, and my 3.9 is spot on I reckon. I agree with blind elk, that being a rally diff. You'd have no problem selling it on Bridibella ( rall site). I dynoed my l28 the other day, made 142@ the wheels. The tune was average apparantley,running way to rich. I have 72 grind coming from POWER PLAY which should be in in a week, current grind 68. Then I'm getting it tuned on a dyno, rather than by ear.
Except the 180B used an R160...
Well for what it's worth, I'm using a 4.11 in the DR30 with same gear ratios for the likes of Wakefield & Winton, but Eastern Creek I'm going to 3.7 and for the PNV with it's L28et and bags of torque I'm going to use a 3.9 R200 LSD with gear ratios of 1. 3.592, 2. 2.246, 3. 1.415, 4. 1.000, 5. 0.813:1
My theory is on cruise in 5th I will get better driveability with the 3.9/0.813 instead of 4.11/0.833
Cheers, D
say if ya wanted to change the ratios in a r180 from 3.9 to say around 4.11. is there a easy swap from another diff or what else used the r180 in those ratios? just swappin the crown and pinion gear. easy to do it on the r31s bw78's. pinni was 4.11 and skylines were 3.7 and 3.9. then vls were 3.45 i think... wondering if something similar with the r30s etc
cheers..
The SR20 box came with a smashed rally car that I bought complete a couple of years back. I swapped the box, diff, L26 and twin carbs, suspension, wheels and tyres into my fairly stock sedan, and all for the bargain price of $4000... most of which has long since been broken or upgraded anyway.
From memory, the box was a standard C210 five speed, split, with the guts of a second hand SR20 box crammed inside. Apparently the Sr20 internals fitted in "like lego."
'Cause the bell housing is still L-series, the tailshaft and cross-member remain stock C210 items. From memory my gear lever is Datsun, but a slightly different shape to the C210 stick (it's 260Z or something random - a slight L shape rather than straight). Even the gear knob is stock C210.
Ill provide more details ASAP, my receipt file is with the car at the tuners.
My vote is 4.1 :happy:
SR20 box swap involves pulling the sr20 or ca18 bellhousing off the box, getting a L series bellhousing.
1 selector shaft hole in the L series bell needs to be drilled out larger.
You need to pull one of the bearings off the sr20/ca18 box and replace it with the one from a L series box as the L series bearing is slightly smaller in diameter (replace bearing while your there)
Minor metal needs to be taken out off the L series bell due to one of the gears JUST touching it.
For more info, theres a tutorial on ozdat.
I did the swap before the tutorial was made, easy as :)
I am going to experiment with a couple of diffs this weekend. If it feels good, Ill send it off to get the LSD conversion.
However, I cant find a page which mentions which ratio came standard with which car!
Skyline C210 3.9:1?
Datsun 240k 4.1:1?
Mr30 ???
Has anyone committed this stuff to memory?
Also found the receipt for the gearbox conversion. $1300 from Mammi Motors in Vic, including brass button clutch, flywheel machining, swapping the internals over. The Sr20 box was supplied by the previous owner.
So is the R30.
But you won't find many IRS S12's around in Aus.
Your best bet for non-CV is 240/260Z automatic - 3.9:1
I wonder if you can fit R30 axles to C210 arms? I would be very surprised if there was no compatibility there. Changing the arms would probably be easiest, if feasible.
Cheers Ricky, that's a really nice offer. I'll see if I can't first find something a bit closer though - we both know that Vic-WA freight stings a bit! On the topic I've got some seat covers for you... If you're interested PM me your details again and we can ship them over.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
