Firstly, ill try and get some pictures up tomorrow.
Im going overseas in a couple of weeks so need to sell my car.
Car is a Wine red R32 with RB25 conversion. Motor has 80 000 km on the clock. Chassis has 150 000 from memory... ill have to confirm that.
The good
Recently the tensioner let go and my valves bent. When replacing them i decided to clean up the whole top end to had all manufacturing imperfections clean up on the head. Also has new head gasket and head surfaced, valves and stem seals, tensioner and idler pulley. Also new exhaust and inlet mani gasket..... so head is pretty much as good as new.
Anyway so car has RB25 conversion.
Still has RB20 g/box.
Mods
Buddy club N+ coilovers all round - Awesome suspension BTW, by far the best ive driven on in its price range.
Greddy type m front mount
3" exhaust turbo back
Exedy heavy duty organic clutch
Few things inside, trust gear knob, omori din gauges.
Bosch 040 fuel pump
unknown aftermarket rear camber arms
Rear spoiler off hole filled and resprayed
32 gtr rear wheels
Turbo smart plumback BOV
Paint work is great condition, comes up a treat, i really wish i had the time get it professionally cut and polished.
What i'd suggest doing
Some of these may well get done if i can find time before i go:
Left rear wheel bearing to be replaced... i have bearing unit sitting in my bedroom, just gotta get out the and change over.
Left rear camber to be adjusted more + or right more - as they are uneven and pulls to the left..... so basically needs a wheel alignment.
It is running rather rich on standard ECU and pops and farts a bit on de-acceleration and dumping a bit too much fuel when it comes on boost, so i'd at-least get a copgy back tune.
Has a dint about the size of a 5c coin on the boot lid, not very deep at all. also a chip about 2mm in diameter on rear quater panel also another small dint on roof. Other than that body is straight.
I have had the engineering check done for car and paid half of the fee ($250) there are a couple of small things required for the cert plus the remaining $250
So thats all i can think of at the moment. I've tried to explain everything i can think of.
Honestly, this car has been very well looked after. Its rarely driven and serviced regularly with mobil 1.
Id really love to spend a month or so getting it to where i want for sale but i simply dont have time.
Price is $8500 negotiable. Feel free to make offers, most likely, best reasonable offer within 2 weeks will get it.
Located in east burbs of Mlebourne
Edited by vitz_n1
Hey all. Real sorry about the delay with pics. just been flat out and everytime i wash my car it bloody rains.
It is not registered with the 25. Just needs to have the engineering finalised. I have the report and receipt, all the needs to be done is finish off the few things that the engineer requires and pay $250. It also has 6 months reg.
Ill try go get some pics now.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
