Axis-D Posted November 14, 2009 Share Posted November 14, 2009 (edited) for a cheap cheap job you could just drill the hole for the tensioner new timing belt, gaskets etc, and whack it all together Where exactly does one drill the hole ? And do you use the same tensioner and RB25 timingbelt ? Edited November 14, 2009 by Axis-D Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-4935797 Share on other sites More sharing options...
TiTAN Posted November 14, 2009 Share Posted November 14, 2009 that info is in the PDF file in the first post of the RB30 thread at the top of this section Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-4935851 Share on other sites More sharing options...
Axis-D Posted November 14, 2009 Share Posted November 14, 2009 ive heard a Laruel/Cefiro crossmember will bolt in(R32) by doing this no modification is required to the engine mounts. Is this true ??? Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-4936047 Share on other sites More sharing options...
fletch rb30 Posted November 14, 2009 Share Posted November 14, 2009 ive heard a Laruel/Cefiro crossmember will bolt in(R32) by doing this no modification is required to the engine mounts. Is this true ??? all the rb blocks have the same engine mounting points, so any rb will fit any rb engined car, the only difference is the heigth of the block, rb30 being 38mm taller than 25 and 26 (and 20??) Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-4936783 Share on other sites More sharing options...
Axis-D Posted November 15, 2009 Share Posted November 15, 2009 Yes i know that. Im talking about engine hitting the bonnet, will fitting the Laruel/Ceffy crossmember give enough room? Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-4937876 Share on other sites More sharing options...
fletch rb30 Posted November 16, 2009 Share Posted November 16, 2009 I think it fits r33 ok. i have seen a few done that dont appear to have any bonnet mods. On my 32 i peeled back the insulation under the bonnet and cut out a small section of the bracing and put the insulation back on. i think i have about 5mm clearance to teh cam pulley cover. Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-4940214 Share on other sites More sharing options...
The Mafia Posted January 6, 2010 Author Share Posted January 6, 2010 Hey guys. here is an update on the build. 1. I decided to bore it and get new pistons - Precision branded. They aren't forged, but a full set of 6 cost me $250. Hastings rings. 2. The Block has been decked 3. All of the exhaust valve guides where cracked, but they simply ground them right back, and countersunk them for a carbon trap. 4. RB26 oil pump was stuffed. Getting another. 5. Did the internal VCT oil feed mod. 6. Head is being shaved to raise the compression to 8.6:1. 7. no balancing.. They built it before I could give them to go ahead. Hoping it should be ok though. 8. Crank Collar Fitted. Will have the engine in about 3 days. Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-5018834 Share on other sites More sharing options...
The Mafia Posted January 8, 2010 Author Share Posted January 8, 2010 just a couple of questions: 1. is there a difference between the RB30 and RB25 Flywheels? 2. Same for the harmonic balancer? Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-5022946 Share on other sites More sharing options...
TiTAN Posted January 8, 2010 Share Posted January 8, 2010 1. i just used the Flywheel from my 25 on the 30, make sure you check the spiggot bush in the crank make sure it suits the 25 gearbox 2. power steering belt is different on the 30 (v belt) Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-5023099 Share on other sites More sharing options...
jangles Posted January 8, 2010 Share Posted January 8, 2010 (edited) get a harmonic balancer to suit your ancillaries. 25 - 25, 30 - 30 Edited January 8, 2010 by jangles Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-5023150 Share on other sites More sharing options...
Just_Rb Posted January 8, 2010 Share Posted January 8, 2010 Hey guys. here is an update on the build.1. I decided to bore it and get new pistons - Precision branded. They aren't forged, but a full set of 6 cost me $250. Hastings rings. 2. The Block has been decked 3. All of the exhaust valve guides where cracked, but they simply ground them right back, and countersunk them for a carbon trap. 4. RB26 oil pump was stuffed. Getting another. 5. Did the internal VCT oil feed mod. 6. Head is being shaved to raise the compression to 8.6:1. 7. no balancing.. They built it before I could give them to go ahead. Hoping it should be ok though. 8. Crank Collar Fitted. Will have the engine in about 3 days. whos doing the the block/engine work as im thinking of doing the same also how much will the finished bottom end cost? Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-5023209 Share on other sites More sharing options...
zebra Posted January 17, 2010 Share Posted January 17, 2010 Hey guys. here is an update on the build.1. I decided to bore it and get new pistons - Precision branded. They aren't forged, but a full set of 6 cost me $250. Hastings rings. 2. The Block has been decked 3. All of the exhaust valve guides where cracked, but they simply ground them right back, and countersunk them for a carbon trap. 4. RB26 oil pump was stuffed. Getting another. 5. Did the internal VCT oil feed mod. 6. Head is being shaved to raise the compression to 8.6:1. 7. no balancing.. They built it before I could give them to go ahead. Hoping it should be ok though. 8. Crank Collar Fitted. Will have the engine in about 3 days. can i ask where you got the pistons from? Im picking up a 30 next weekend Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-5039345 Share on other sites More sharing options...
The Mafia Posted January 18, 2010 Author Share Posted January 18, 2010 I didn't get them - The Machine shop did. Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-5040973 Share on other sites More sharing options...
zebra Posted January 20, 2010 Share Posted January 20, 2010 Got the engine yet? Im ordering the same pistons I hope they are all good but for $215 delivered i might buy 2 sets lol Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-5045509 Share on other sites More sharing options...
Dj laBBy Posted January 20, 2010 Share Posted January 20, 2010 Where and who did you get the precision pistons through?? anyone heard of these being ok?? Can't say i've really heard of them. Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-5045613 Share on other sites More sharing options...
zebra Posted January 20, 2010 Share Posted January 20, 2010 http://www.precisionintl.com/HTML/locations.html they sell direct or any repco, auto1 or autobarn can get them...they are only cast factory replacments. They do a "hypatec" or forged piston for rb30et only, so the cast ones are the only real option for a hybrid....unless you want 7:1 comp Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-5045639 Share on other sites More sharing options...
Dj laBBy Posted January 20, 2010 Share Posted January 20, 2010 (edited) http://www.precisionintl.com/HTML/locations.htmlthey sell direct or any repco, auto1 or autobarn can get them...they are only cast factory replacments. They do a "hypatec" or forged piston for rb30et only, so the cast ones are the only real option for a hybrid....unless you want 7:1 comp Cool, its for a rb30et only anyway. Will give them a call tomorrow Thanks Rob Edited January 20, 2010 by Dj laBBy Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-5045785 Share on other sites More sharing options...
MBS206 Posted January 24, 2010 Share Posted January 24, 2010 http://www.precisionintl.com/HTML/locations.htmlthey sell direct or any repco, auto1 or autobarn can get them...they are only cast factory replacments. They do a "hypatec" or forged piston for rb30et only, so the cast ones are the only real option for a hybrid....unless you want 7:1 comp Precision make a forged RB30DET one as well (Or did when I looked it all up about 6 months ago) I had pricing for them. Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-5051593 Share on other sites More sharing options...
unique1 Posted January 24, 2010 Share Posted January 24, 2010 im using the same pistons (endurotech i think they are called, made by Precision) in my 26/30, they were cheap and due to the lip on the bores i needed to go .20 oversize anyway and forgies were alot more, and then you need rods as well, so i said for $200ish they are worth it. If it blows up who cares Mines running 22psi with a gt3076r and is fine (though cam timing is not right so lacking power). I've just put together a second 26/30 right now with another set and going to be running a hks t04z on it and push it pretty hard and see what it can do. Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-5051784 Share on other sites More sharing options...
MBS206 Posted January 24, 2010 Share Posted January 24, 2010 im using the same pistons (endurotech i think they are called, made by Precision) in my 26/30, they were cheap and due to the lip on the bores i needed to go .20 oversize anyway and forgies were alot more, and then you need rods as well, so i said for $200ish they are worth it.If it blows up who cares Mines running 22psi with a gt3076r and is fine (though cam timing is not right so lacking power). I've just put together a second 26/30 right now with another set and going to be running a hks t04z on it and push it pretty hard and see what it can do. I like the way you work... Sounds a bit like mine, except I didn't even rebuild it... Just need to change a few things, then push its limits... Link to comment https://www.sau.com.au/forums/topic/294180-the-mafias-povo-rb30-build-cheap-but-not-nasty-some-real-simple-questions/page/2/#findComment-5051787 Share on other sites More sharing options...
