hey all
just bought my new r33 gts-t series one
im having a lil flashing icon which turns out to be the 'check oil' icon when im boosting sometimes
maybe its the way im driving it but it sometimes turn on and sometimes doesnt.
ive checked the engine oil level with that lil metal dipper and it seems to have recent healthy looking engine oil
anyone know why this is?
cheers
Look at the level when cold (ie. wait at least 10 minutes after shutting engine off). Sure it's not an oil pressure warning? because if it is you definitely do not want to ignore that
edit: If it is indeed oil pressure, I'd hate to say, but you may haee brought yourself a lemon.
hey
so how do i no if its the oil pressure or not?
yeh i have a apexi powerfc with the controller, dun really know how to use it
car has had new engine put in not a year ago.
shouldnt be knocking or anything like that..?
its that orangey icon at the top right of the dash.
any one know?
so its the check engine light?
hoping its not set to high knock levels or you could be changing the engine yet again.
would recommend you get it to a tuner pretty quickly for diagnosis and possibly re tune.
yeh i just looked at it
its the 'check engine' icon flashes SOMETIMES
wen im boosting.
car has highflowed turbo, turboback exhaust, powerfc etc
it was tuned before but last owner put a fmic on and it hasnt been tuned yet.
he recommended that i get it tuned aswell.
so im better off if i take it to a shop and dont drive it to its edge just yet?
you can check your knock levels on the hand controller display, go to the correct page and it will give you a read out with peak hold, but if your light is coming on then its +60 or thereabouts.
standard AFM? doesnt the "check engine" light come on when the afm gets maxed out aswell?
How quick is it flashing. I cant remember which way it is, but one is knock, and other is AFM from what ive read up.
this sounds similar to what my car used to do before....the tune wasn't the best and it knocked every time around the 40-70 mark....got it retuned and now barely seeing any knock.....so as others have recommended take it to a decent tuner and get your power fc retuned.....and save yourself have to slap in another motor
that light is ur piston saying hi, if you ignore the light long enough ur piston might actualy decide to exit the block and say hi in person.
definately dont drive the thing hard if its knocking, take it for a proper tune :(
hi,
covered to death in the powerfc faq (in my signature) read it and check if its the AFM, Injetors or knock causing the engine check light to come on
to clarify, the engine check light is orange, this is a warning sequence light, as the colour is orange
the oil pressure light, is red, and is a critical sequence, as the colour is red
the orange engine check light is used (with the powerfc) to identify maxing sensors, broken sensors and excessive detonation
isolate the cause for the orange light flashing by using advice in here and the FAQ
have the hand controler? you can adjust it in there what knock level it comes on. if its set to 50 or somethi ng you need to have a look at the tune.
you cant adjust the threshold with the hand controller, you need datalogit to do that. standard setting in the pfc is anymore than 60 knock flashes the engine light
use the temp adjust to take a couple degrees of timing out until you get it tuned
so knocking is a normal thing?
im pretty sure its standard AFM
the powerfc i have no idea how to use, but the check engine light flashes a lil bit
and it doesnt so much knock on the hand controller.
how do i check wat level its set to? also ive read that FAQ briefly but dun really know wat im after
it siad something about hitting the limiter and the engine is knocking slightly?
since the ECU has been changed, would i focus on the handcontroller 's readings or the dashes??
my r32 didnt used to do this? but that was stock :P
not really sure wat to do atm lol
that tune is coming tho
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
