the problem: less coolent in radiator after drive,I need top up everytime when engine is cool(about 250ml sometime more sometime less). the coolent in overflow bottle is getting more and more. so thats mean: coolent flow to overflow bottle when hot, but when cool down the coolent not fully go back to radiator. i did some record. the coolent still go in to radiator when cold but not as much as the coolent from radiator to overflow bottle when hot. say coolent from radiator to overflow bottle 500ml when hot, when its cool down the coolent only come back to radiator 250ml.
I went to a few place to check the cooling system. all good. no problem at all. all of them suggest me try to change a cap.
then I bought a new radiator cap(1.3bar), nothing changed.
but my car never overheat always 75-85degree on PFC. can i just drive like this? don't need really care about it??? I worried the coolent in radiator will getting less and less during time.
I got arc radiator and nismo cap.
car is r34gtr.
anyone help please!!!
the fact that if isn't drawing coolant back into the radiator suggests there is something wrong. if you have a new cap, then i would be looking at the overflow bottle or the hose to the overflow bottle. there may be a small amount of debris at the bottom of the overflow bottle that is allowing the coolant to come in, but when it tries to suck it back in it is blocking up the hole and not letting it back in.
If it's not the cap then it is likely the tube running form radiator overflow or quite possibly the nipple on the radiator. My thoughts are that the force of fluid coming out of the radiator when hot is high but the force under vacuum for refilling when cold is low. The hole might have corroded or the hose is partially blocked.
The hole in my aluminium radiator was blocked from a little bit of crap, I just scraped it out with a drill bit.
First thing to do is to look for coolant stain's over your engine block, top of gearbox at rear, around hoses ect, my next thing would be respective of head gasket or turbo seals.
its still about 150ml coolent less in radiator. the coolent should be full in radiator no matter engine burn water or not is that right?? if the engine burn water the coolent in overflow bottle should getting lower not the coolent in radiator?
PS: I have nismo water pump
Edited by Nosure
if the motor is using coolant it will use it from the radiator first then the overflow.
either you have a small leak which is only evident under pressure or you have a headgasket issue.
even the engine using some coolant does the radiator should still full? and the overflow should get less coolant?
the radiator should always be full. The overflow bottle is an expansion chamber basically when the coolant is hot, it expands and some is pushed to the overflow bottle and then taken back into the radiator once cool.
what you need to do, is fill the rad with bleed screw on the manifold taken out til the system is full. then reseal the system, make sure the overflow bottle is filled to the MAX line and then mark it.
drive for a few days and then re check it.
if you have lost coolant from either the rad or the overflow then you either have a leak or a gasket problem, simple as that
better way to bleed system. leave your cap and cock on the top of your manifold off, run the car up to op temp and let all air in the system bleed out thoroughly.
making sure your overflow is half full?
thanks mate but where is the bleed screw?? and how can I do it?? some more detail please
OK I will try it. thanks mate
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
