Check this out.
Broken transfer case chain... snapped and punched through the casing at 7 km/h.
Dose anyone have a breakdown parts diagram/picture of the transfer case?
Has anyone ever seen this? Are there any common faults to look for?
Car specs: 33 GTR- 860 odd bhp, stock box/case, 2.6 forged with a single billet precision turbo and supporting mods. Street tyres, some spirited driving and lots of dyno time (box number 3).
Any advice or the parts break down diagram would be great.
Cheers
Justin
https://www.sau.com.au/forums/topic/294273-broken-transfercase-7kmh/
well..I've broken a transfer case chain too, but I've never heard of anyone else doing it.
In my case the xfer case had just been rebuilt, took it racing at targa and the 4wd slowly failed until the chain broke/smashed the box selector so I had to retire.
I assume that the clearences in the rbuild were incorrect causing some sort of bearing to fail and seizing the FWD portion of it, which in turn broke the chain next time I launched.
There are a couple of places around who can rebuild them, but I just chose to get a seoncd hand one for about $400 and not touch it, has been running fine for 2 years of racing since :happy:
Hey mate, the part number for the chain is 3315205U00. It's about 600 bucks new. I'm redoing a transfer case at the mo and there's probably a few more things you'll need to look at, but I reckon the hole in the case might be a issue. Def cheaper to get a second hand one for about 200- 400. If you want more info on the case internals and part numbers let me know.
Andrew
  • 1 month later...
  • 3 weeks later...
AWD Dyno
Update: Car is getting a new plenum and individual tb... going for 900 at the wheels.
AWD dyno kills the attessa as you've just found out.
You need to run it in RWD mode on the dyno to prevent drivetrain issues. Sure it works for a short time but in the end they don't like it. I pull the fuse i the boot :rant:
    • I'm not aware of e30 in Australia, but I'm pretty sure e85 is still around. You really want a setup with an ethanol sensor so you can run any mix of ethanol depending on what you can access. Fuel Check NSW app shows 14 site in sydney metro with e85. What are you adding, will you put in bigger turbs too? Apparently the wastegates are pretty small and can't bypass enough as you run more boost.  I'm sticking to 1.3 bar with 98 on the standard turbos with my tune on advice from the tuner, and boost drops significantly in the top end; apparently larger turbos with larger wastegates are needed to get anywhere meaningful from there.
    • Amazing work Duncan! It is never easy to pick up someone elses project and work all the parts out that are missing
    • Hey Ppl,   I am about to tuned my Infiniti Q60 with E-85 and if you can tell me some location where I can top up my car that would be great.   But my other question, is E-30 available because this tuned requires less mods parts and any info you can offer would be greatly appreciated too!!
    • Hey Duncan,   The parts have already been made by AMS Performance in Chicago, but I still to confirm if there are in Petrol Station in Sydney that sell E-30.   I know there are a few seeling E-85.
    • That probably needs a specific thread....and if you want to run different ethanol mixes you will need the ethanol sensor and wire it into the ECU (which has different requirements depending on the ECU year apparently)
