Hey there peeps.
I think I've decided on Bilstein shockies for my 34 because I can lower the ride height without needing new springs, which also means I keep the progressive rate of the standard springs = comfort when cruising but firmness when cornering hard (to my knowledge).
My question is; am I going for the sport version or the comfort version?
And how much have people been paying for these? I was quoted $1k for all four but I didn't ask or get told whether this was for sport or comfort.
Thanks in advance for your comments.
https://www.sau.com.au/forums/topic/29429-bilstein-shockies/
Bilsteins are Bilsteins - AFAIK, they don't come in different 'comfort settings' (although you might be able to have them custom valved).
Shocks are there to control the springs. The springs are what supports the car, and what gives comfort (or lack of it) in the ride. It could be that the standard springs will be too soft for the Bilsteins. I have Kings in my R32 GTS4, rated around 280 lb - Quadrant here in Melbourne recommend something like 430 lb springs for their Bilsteins to suit a R32 GT-R.
If you want cornering, you fit sway-bars.
I got a set for the GTS4 for around $1k, so the price you have been quoted sounds about right.
https://www.sau.com.au/forums/topic/29429-bilstein-shockies/#findComment-601819
Ah thanks for that. I just realised that it was the Bilstein Hot Rod shocks that come in comfort and sport. I read the thing wrong.
I have been told that the Bilsteins will last 50k with the standard springs and this persons opinion was that it was worth it for the comfort factor.
https://www.sau.com.au/forums/topic/29429-bilstein-shockies/#findComment-601855
Bilsteins like all hydrualic devices, have velocity sensitive valving so they accept a wide range of spring rates. They are also multi valved in both compression and extension, so they damp an even wider range of spring (and velocity rates) then single or dual valve shocks. Unlike some things in life you do get more for your money when you buy a decent shock absorber.
Bottom line, off the shelf Bilsteins will work just fine on standard springs and accept the usual 20% to 25% upgrade in spring rates you get with lowered, off the shelf sports springs. Obviously competion rates are a different matter, where revalving is always required.
Hope that helps
https://www.sau.com.au/forums/topic/29429-bilstein-shockies/#findComment-606938
again sydneykid comes thru with the goods!
I actually just bought a set of these bilsteins, SPORT model, as sold by UAS, and cost me easily under a grand. I think they sell them for 920$ a set but i got them a bit cheaper.
As for the springs, im running Kings lows (progressive rate rears) and Kings quote them as 180lb fronts and 175lb rears, and i had them spring tested just to confirm. I also tested my std springs for comparison and i think they were around the 140lb mark, so the kings are about 25% firmer.
Before i ordered the bilsteins i spoke to the aus distributor for bilsteins and the guy was happy when i said i was using kings springs, and that they would be an excellent match.
Blind elk, 280lb in your kings is higher than the usual for them, did you have them custom made at that rate? As for street that is very firm.
Also 430lb springs is VERY firm, too firm for street unless you like drift style- the teins in my car at the moment are over 400lb and unless the road is good, its very bumpy. UAS recommend UP TO 400lb springs for their 300zx track car.
-i pick my shocks up tomorrow, when i get them in ill put up a review.
https://www.sau.com.au/forums/topic/29429-bilstein-shockies/#findComment-607336
Abo Bob, i did a fair bit of reading and research before buying my bilsteins, and the sport shocks are described as 'firm', but also something bilstein describe as 'self-adjusting', and work well with the progressive rate springs, and maintain a certain amount of comfort at the same time.
I also looked at KYB shocks as used in HPI's R34, the externally adjustable ones, and the bilsteins are meant to be better for the money, and apparently you dont need the adjustability in a street setup for these shocks with std/upgraded springs.
https://www.sau.com.au/forums/topic/29429-bilstein-shockies/#findComment-607356
Hi guys it always amazes me how people avoid gettting their wheel alignment checked. I check the race cars' alignment every time they go out. It is so important to how your car handles and drives and it can save you way more than the cost in tyre wear alone.
It is unbelievable the number of times I have seen cars with $000's spent on springs and shocks that handle badly because their suspension geometry is all over the place.
My 20 cents worth Sly33, get it wheel aligned.
https://www.sau.com.au/forums/topic/29429-bilstein-shockies/#findComment-621663
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
